Singularity Posted May 10, 2014 Share Posted May 10, 2014 I have created a product in WHMCS and I selected a 'comparison' template during the creation of the product. I also have 3 options for this product, but now how do I get this template and all the details of the product to display on the site on the front end? I did find the information to get some of the information on here http://docs.whmcs.com/Data_Feeds#Product_Pricing but this doesn't tell me how to get the comparison template to display as well? Please could someone advise. Thank you 0 Quote Link to comment Share on other sites More sharing options...
zomex Posted May 10, 2014 Share Posted May 10, 2014 Hello, By default WHMCS will only add these products to the cart.php page. But you can create your own pages in WHMCS to advertise your plans. For example creating WHMCS_path/web-hosting.php following the below guide and displaying your plans: http://docs.whmcs.com/Creating_Pages Regards, Jack 0 Quote Link to comment Share on other sites More sharing options...
Singularity Posted May 12, 2014 Author Share Posted May 12, 2014 Thank you for your response. I am going to have to find someone who is a pro at php coding to help me get this whole integration thing working the way I need it to work. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted May 12, 2014 Share Posted May 12, 2014 another way might be to download a whmcs template, some are free, and use that to start off with... or if you know some html, and you only want to add links to this product on your opening page, you could edit homepage.tpl to add links and/or descriptions to the page. 0 Quote Link to comment Share on other sites More sharing options...
Singularity Posted May 13, 2014 Author Share Posted May 13, 2014 Thank you ... I have a Joomla installation with a template for Joomla, I thought that WHMCS was supposed to be the backend and engine for the requirements, not that it is actually a site all by itself. I wouldn't know how to go about changing what has already been done, so I am going to have to find someone who is experienced in this type of setup to help me. Thanks again for your help. 0 Quote Link to comment Share on other sites More sharing options...
