Problem registering .ES domains - resellerclub module
msaunders
Hi
Just spotted an issue when ordering .ES domains via resellerclub module . There are a few option fields that need to be filled in by the customer but the drop downs are totally blank . Looks like its supposed to pull in the data from the language file but its not working ... anyone else have this issue or know of a fix ?
I am using 5.0.3 and I checked my english.php and additionaldomainfields file and they are the correct versions from what I can see - also I have the latest resellerclub module (5.0.3 build)
TIA
Martin
  • WHMCS Product Manager
Upgrading to 5.1.2 will resolve this. Otherwise please try the following in your /includes/additionaldomainfields.php file in v5.0.3:
// .ES
$additionaldomainfields[".es"][] = array("Name" => "ID Form Type", "LangVar" => "estldidformtype", "Type" => "dropdown", "Options" => "Other Identification,Tax Identification Number,Tax Identification Code,Foreigner Identification Number", "Default" => "Other Identification",);
$additionaldomainfields[".es"][] = array("Name" => "ID Form Number", "LangVar" => "estldidformnum", "Type" => "text", "Size" => "30", "Default" => "", "Required" => true,);
Thanks John but with all the issues with 5.1.2 being reported I wont be upgrading just yet.
I tried your suggestion , those lines were already in /includes/additionaldomainfields.php and it made no difference - anything else I can do ?
Edited by msaunders
