jackc Posted December 24, 2010 Share Posted December 24, 2010 Hello, I'm running into problem with whmcs and directadmin auto-provision. I have multiple servers with DirectAdmin installed and with different hosting packages in each server. For example: Server 1 has Package1 Server 2 has Package2 I have tried serveral times that WHMCS is only able to auto-provision accounts for the server set to default. "This is where you configure all your servers so that WHMCS can communicate with them. The default server for each module is marked with an asterisk *. You must select a default server for automatic setup to function correctly." When I have Server1 set to default, WHMCS will not be able to auto-provision accounts if a client sign up for Package2 which it's in Server2. There will be an "can not resolve host" error in the activity log. Anyone ran into this problem before? Is there a solution to this? Regards, Jack 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted December 28, 2010 WHMCS Product Manager Share Posted December 28, 2010 If you want to do that you'll need to create two server groups, add server 1 to group 1 and add server 2 to group 2. Then you can specify which server the product is created on under Setup > Products/Services > Edit > Module Settings tab. 0 Quote Link to comment Share on other sites More sharing options...
jackc Posted January 2, 2011 Author Share Posted January 2, 2011 tried that with several servers, got "can not resolve host". unless the server is marked "default server" 0 Quote Link to comment Share on other sites More sharing options...
nobaloney Posted April 6, 2011 Share Posted April 6, 2011 tried that with several servers, got "can not resolve host".unless the server is marked "default server" Has this ever been resolved? I need something similar. 0 Quote Link to comment Share on other sites More sharing options...
