suhosting Posted May 26, 2010 Share Posted May 26, 2010 Hello, i am very novice in this topic of WHMCS. I am trying to setup my registrars domains provider that is ResellerClub, I followed the manual instructions whmcs, and I am quite sure that I am entering username, password and Parent ID correctly, but whenever I try to make a Domain Registration get the error Inavalid Username / password or your account may be suspended or inactive, and none of these reasons apply. where you can be wrong? Very thanks for your help 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Support Manager WHMCS John Posted May 28, 2010 WHMCS Support Manager Share Posted May 28, 2010 In the "Username" field enter the email address you use to login to ResellerClub. 0 Quote Link to comment Share on other sites More sharing options...
Dominik Posted May 28, 2010 Share Posted May 28, 2010 Are you sure you didn't put your ResellerID, instead of the ParentID ? ResellerID got 5 numbers, parentID - only one number (at least for me). Kindly check that. 0 Quote Link to comment Share on other sites More sharing options...
netearth Posted May 31, 2010 Share Posted May 31, 2010 As Dominik stated, if you are a direct RC reseller the parentID should be 1. If you are not a direct RC reseller, then it is the resellerID of your parent reseller. Go to settings >> personal information >> primary profile in RC to check. 0 Quote Link to comment Share on other sites More sharing options...
