n8b Posted April 13, 2010 Share Posted April 13, 2010 Hi, I'm currently running on the trial of WHMCS, and I'm going to buy as soon as I can get this working.. but that's the problem, I'm having issues with having accounts created. So I've added a server, a server group, and a shared web hosting product. I've added the user and password of my account. I have the product set to use the server group, and have it set to automatically create an account after order completion. The problem is, whenever i test my order, it goes into pending, even though it should be automatically created. So I go in, and manually check the pending order and accept them, however, an account is still not created. Via the customer area, the package eventually sits to active (after I manually accept it), and there is a username and password sitting there, but neither of them work, or allow access to cPanel. I log into WHMCS, and the such client account isn't even in the system, as if it wasn't created. I'm probably missing something major here, but can i get any help? As soon as I can get this system working, I'm happy to buy it, but I just don't want to purchase and still be digging my hair out.. Thanks! -Nathan 0 Quote Link to comment Share on other sites More sharing options...
n8b Posted April 13, 2010 Author Share Posted April 13, 2010 Any ideas what I could be doing wrong? 0 Quote Link to comment Share on other sites More sharing options...
Kenneth F Posted April 13, 2010 Share Posted April 13, 2010 Same for me. What am I missing? I thought that the WHMCS would create a new cPanel account -- but I don't see it getting created. Hi, I'm currently running on the trial of WHMCS, and I'm going to buy as soon as I can get this working.. but that's the problem, I'm having issues with having accounts created. So I've added a server, a server group, and a shared web hosting product. I've added the user and password of my account. I have the product set to use the server group, and have it set to automatically create an account after order completion. The problem is, whenever i test my order, it goes into pending, even though it should be automatically created. So I go in, and manually check the pending order and accept them, however, an account is still not created. Via the customer area, the package eventually sits to active (after I manually accept it), and there is a username and password sitting there, but neither of them work, or allow access to cPanel. I log into WHMCS, and the such client account isn't even in the system, as if it wasn't created. I'm probably missing something major here, but can i get any help? As soon as I can get this system working, I'm happy to buy it, but I just don't want to purchase and still be digging my hair out.. Thanks! -Nathan 0 Quote Link to comment Share on other sites More sharing options...
webhost 4 less Posted April 13, 2010 Share Posted April 13, 2010 Hi Guys, Try this..... Go to products and services and find the product you are testing, go into the and head to the module table (this is the cpanel set up bit) look at the bottom and make sure its set to either: Automatically setup the product as soon as an order is placed Automatically setup the product as soon as the first payment is received Then click save and try it again and it should work. Cheers Jim 0 Quote Link to comment Share on other sites More sharing options...
n8b Posted April 13, 2010 Author Share Posted April 13, 2010 Hello webhost 4 less, I have already taken a look at this section, and I've had it set to "Automatically setup the product as soon as an order is placed" and the issue continues. I'm starting to pull my hair out! I have my cron jobs setup, I have the hash inserted that WHM kicked back, and I'm able to login with the WHM button. My server information is correct, I've created a group for the product, everything.. But I'm sure there must be some small thing I'm missing. Thanks for trying to help, Jim, it's appreciated. Still trying to figure this out Any luck Kenneth? 0 Quote Link to comment Share on other sites More sharing options...
bear Posted April 14, 2010 Share Posted April 14, 2010 I log into WHMCS, and the such client account isn't even in the system, as if it wasn't created. Do you mean you log into WHM and the account isn't created, or WHMCS, the script you're trialing? I'm sure there must be some small thing I'm missing. Assuming it's a reseller account you're connecting to to create that hosting account, did you also create a package in WHM and add that name into WHMCS for it? 0 Quote Link to comment Share on other sites More sharing options...
n8b Posted April 14, 2010 Author Share Posted April 14, 2010 When logged into WHM, the account isn't created. WHMCS has the customer details, and when doing a test client, they even get a username and password for cPanel, however, neither the username or password work, as WHM hasn't created the account. And this is actually running off a VPS I have. I've set the cron jobs, added the hash, added the servers, added a server group to the package, and yeah, WHM also has packages of the same name as the product. 0 Quote Link to comment Share on other sites More sharing options...
n8b Posted April 15, 2010 Author Share Posted April 15, 2010 When logged into WHM, the account isn't created. WHMCS has the customer details, and when doing a test client, they even get a username and password for cPanel, however, neither the username or password work, as WHM hasn't created the account. And this is actually running off a VPS I have. I've set the cron jobs, added the hash, added the servers, added a server group to the package, and yeah, WHM also has packages of the same name as the product. I couldn't find an edit button, sorry to double post. But this issue has been resolved, thanks to the staff. There was an error with the hash, I guess. Thanks! 0 Quote Link to comment Share on other sites More sharing options...
