Nave Posted November 25, 2009 Share Posted November 25, 2009 Hello, I'm trying to set up WHMCS with a Dotnetpanel server and I have all the packages and the server set up with the correct information, useing the serveradmin account, When I try to get an account set up it never goes through and when I try to create it manually I get this error at the top of the page. Module Command Error wsdl error: HTTP ERROR: Unsupported HTTP response status 400 Bad Request (soapclient->response has contents of the response) any ideas? 0 Quote Link to comment Share on other sites More sharing options...
Onionman Posted November 25, 2009 Share Posted November 25, 2009 Are you using PHP 5 and do you have SOAP enabled? 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted December 11, 2009 Share Posted December 11, 2009 did anyone get a solution to the php5/soap problem ? 0 Quote Link to comment Share on other sites More sharing options...
abertina Posted December 30, 2009 Share Posted December 30, 2009 SOLVED. this is not a php5/soap problem you must configure you dotnetpanel to work with WHMCS. whmcs try to connect to dotnetpanel enterprise server by IP but by default dotnetpanel doesn't accept IP and it needs host name. because of that dotnetpanel say: 400 Invalid Host Name. you mus go to your dotnetpanel server and configure iis to accep both ip and hostname for dotnetpanel enterprise server together. 0 Quote Link to comment Share on other sites More sharing options...
Onionman Posted January 1, 2010 Share Posted January 1, 2010 did anyone get a solution to the php5/soap problem ? The current module requires that PHP 5's inbuilt SOAP function is NOT enabled or it will fail. A new module with PHP 5 SOAP support should be available soon. 0 Quote Link to comment Share on other sites More sharing options...
ezyweb Posted January 26, 2010 Share Posted January 26, 2010 I don't know whether you've found an answer to this problem yet, but the issue lies with how you first setup up the IPs for each element of DNP. If you chose the defaults of 127.0.0.1 for DNPServer and DNPEnterpriseServer, then trying to reach them from WHMCS will fail every time .. unless of course, you're running WHMCS off the DNP server, but why would you? What you need to do is change the IP of the DNPEnterpriseServer to a publicly accessible IP. Remember to update this new IP in the DNPPortal as well, or the GUI won't be able to communicate with anything. Do NOT add a hostname. This is not necessary for DNPEnterpriseServer and can cause more trouble than it's worth if you do. Now, update your DNP Server config in WHMCS to use the new publicly accessible IP for DNPEnterpriseServer, and everything will work exactly as its meant to. 0 Quote Link to comment Share on other sites More sharing options...
SimonM Posted February 22, 2010 Share Posted February 22, 2010 i've got past the soap error by setting iis to listen on a puplic ip .. but now a new error. Module Command Error System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetPanel.EnterpriseServer.UserCreationWizard.CreateUserAccountInternal(Int32 parentPackageId, String username, String password, Int32 roleId, String firstName, String lastName, String email, String secondaryEmail, Boolean htmlMail, Boolean sendAccountLetter, Boolean createPackage, Int32 planId, Boolean sendPackageLetter, String domainName, Boolean tempDomain, Boolean createWebSite, Boolean createFtpAccount, String ftpAccountName, Boolean createMailAccount) at DotNetPanel.EnterpriseServer.UserCreationWizard.CreateUserAccount(Int32 parentPackageId, String username, String password, Int32 roleId, String firstName, String lastName, String email, String secondaryEmail, Boolean htmlMail, Boolean sendAccountLetter, Boolean createPackage, Int32 planId, Boolean sendPackageLetter, String domainName, Boolean tempDomain, Boolean createWebSite, Boolean createFtpAccount, String ftpAccountName, Boolean createMailAccount) at DotNetPanel.EnterpriseServer.esPackages.CreateUserWizard(Int32 parentPackageId, String username, String password, Int32 roleId, String firstName, String lastName, String email, String secondaryEmail, Boolean htmlMail, Boolean sendAccountLetter, Boolean createPackage, Int32 planId, Boolean sendPackageLetter, String domainName, Boolean tempDomain, Boolean createWebSite, Boolean createFtpAccount, String ftpAccountName, Boolean createMailAccount) --- End of inner exception stack trace --- and in DNP it shows Information 2/22/2010 5:28 PM 5:28 PM User Delete yyttyuty serveradmin Information 2/22/2010 5:28 PM 5:28 PM User Add yyttyuty serveradmin looks almost as if it adds the new user then immediately deletes it 0 Quote Link to comment Share on other sites More sharing options...
SimonM Posted February 22, 2010 Share Posted February 22, 2010 (edited) i've got past the soap error by setting iis to listen on a puplic ip .. but now a new error. Module Command Error System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetPanel.EnterpriseServer.UserCreationWizard.CreateUserAccountInternal(Int32 parentPackageId, String username, String password, Int32 roleId, String firstName, String lastName, String email, String secondaryEmail, Boolean htmlMail, Boolean sendAccountLetter, Boolean createPackage, Int32 planId, Boolean sendPackageLetter, String domainName, Boolean tempDomain, Boolean createWebSite, Boolean createFtpAccount, String ftpAccountName, Boolean createMailAccount) at DotNetPanel.EnterpriseServer.UserCreationWizard.CreateUserAccount(Int32 parentPackageId, String username, String password, Int32 roleId, String firstName, String lastName, String email, String secondaryEmail, Boolean htmlMail, Boolean sendAccountLetter, Boolean createPackage, Int32 planId, Boolean sendPackageLetter, String domainName, Boolean tempDomain, Boolean createWebSite, Boolean createFtpAccount, String ftpAccountName, Boolean createMailAccount) at DotNetPanel.EnterpriseServer.esPackages.CreateUserWizard(Int32 parentPackageId, String username, String password, Int32 roleId, String firstName, String lastName, String email, String secondaryEmail, Boolean htmlMail, Boolean sendAccountLetter, Boolean createPackage, Int32 planId, Boolean sendPackageLetter, String domainName, Boolean tempDomain, Boolean createWebSite, Boolean createFtpAccount, String ftpAccountName, Boolean createMailAccount) --- End of inner exception stack trace --- and in DNP it shows Information 2/22/2010 5:28 PM 5:28 PM User Delete yyttyuty serveradmin Information 2/22/2010 5:28 PM 5:28 PM User Add yyttyuty serveradmin looks almost as if it adds the new user then immediately deletes it edit :::: fixed this also now. issue was not reading instructions and human eye catching the thing on a line http://xxx.xxx.xxx.xxx:9001/Default.aspx?pid=HostingPlans&mid=19&ctl=edit_plan&PlanID=4&UserID=1 one of the settings needed is the plan id.. and when i look at the line above the 1st thing i saw was "Plans&mid=19" so all days today i have been banging away trying to make it work . it even forced me to get php4 up and running side by side with php5 to see if that was an issue. and then finally i looked it all over again .and noticed planID-4 . not 19 and as if by magic it all works now.. another issue now tho. i could not get WHMCS working at all with php4 . i'm guessing it was a php_curl issue as even with it uncommented as an extension in php4 it still does not load, i did not go as far as sticking the extra libeay dll's in the winblows dir as i did not want to rick breaking php5 Edited February 22, 2010 by SimonM 0 Quote Link to comment Share on other sites More sharing options...
JofleyUK Posted February 22, 2010 Share Posted February 22, 2010 winblows dir The best description of Windows i have EVER Seen. A typo with some humour! Back to Topic, PHP4?? Would you not be better completely removing PHP4 as its a little old hat nowwadays and having both on your system could cause issues. I know you have it there for older software compatibility but... well you know where i stand. i would remove it completely. 0 Quote Link to comment Share on other sites More sharing options...
plusplushosting Posted February 28, 2010 Share Posted February 28, 2010 Just to add my experience in this....i have been getting this error when i have attempted to create a user account....end up being because the user First name had an accent in a letter...so special characters in the user info can cause it......add it in your list 0 Quote Link to comment Share on other sites More sharing options...
