aymane07 Posted October 26, 2009 Share Posted October 26, 2009 Hello, I would really appreciate your help. In the default template, the menu (before login) is horizental and is located in the header.tpl in the portal template however, the menu (before login) is vertical in the right. I can't find where to change it in the template files. 2nd, i want to have a vertical menu in the default template, does anyone know how to do that? thanks a lot for your help 0 Quote Link to comment Share on other sites More sharing options...
aymane07 Posted October 26, 2009 Author Share Posted October 26, 2009 I found the portal menu in the footer.tpl, but when i tried adding the code to the footer in the default template, it appears after the homepage, any hints on how i can keep it to stay to the left and the homepage to the right? thanks a lot 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted October 27, 2009 Administrators Share Posted October 27, 2009 In the default template you'd need to add it to header.tpl. 0 Quote Link to comment Share on other sites More sharing options...
