totalprocessing.com Posted October 17, 2009 Share Posted October 17, 2009 Hi, I am not able to access my WHCMS through my SSL. My SSL is setup like this https://safe-order.totalhostingservices.com and WHCMS is setup http://totalhostingservices.com/clients. When I try to access whmcs securely it tells me the licenses is invalid. Is there any workaround for this? Thanks 0 Quote Link to comment Share on other sites More sharing options...
DedicatedPros Posted October 17, 2009 Share Posted October 17, 2009 You'd need to get a second license... 0 Quote Link to comment Share on other sites More sharing options...
totalprocessing.com Posted October 17, 2009 Author Share Posted October 17, 2009 Is it possible just to revoke my licesnse I have and reissue it for safe-order.totalhostingservices.com? They are both the same web site. 0 Quote Link to comment Share on other sites More sharing options...
thehost5968 Posted October 17, 2009 Share Posted October 17, 2009 yes change where the WHMCS files are then Go to WHMCS's clientaera and reisue it then the next time you or a client uses WHMCS it will update. 0 Quote Link to comment Share on other sites More sharing options...
thehost5968 Posted October 17, 2009 Share Posted October 17, 2009 Sorry but as this would be a domain name change you will need to put a ticket in to WHMCS asking for it to be changed 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Support Manager WHMCS John Posted October 19, 2009 WHMCS Support Manager Share Posted October 19, 2009 No need to open a ticket, reissuing the licence is all that's needed. The SSL and non-SSL need to use the same URL eg: http://secure.mysite.com https://secure.mysite.com 0 Quote Link to comment Share on other sites More sharing options...
