eMaygo Posted August 29, 2009 Share Posted August 29, 2009 Hii WHMCS, my web site: http://www.emaygo.com/destek but whmcs is not working... ________________________________________________ This eror massagge: Down for Maintenance An upgrade is currently in progress... Please come back soon... ________________________________________________ i use server properties [[[root@webler:~]]]php -v PHP 4.3.9 (cgi) (built: Jul 16 2008 16:44:47) Copyright © 1997-2004 The PHP Group Zend Engine v1.3.0, Copyright © 1998-2004 Zend Technologies with the ionCube PHP Loader v3.1.26, Copyright © 2002-2006, by ionCube Ltd., and with Zend Extension Manager v1.2.2, Copyright © 2003-2007, by Zend Technologies with Zend Optimizer v3.3.0, Copyright © 1998-2007, by Zend Technologies [[[root@webler:~]]] _________________________________________________ it doesn't work what can i do for using again ? help Me plz... 0 Quote Link to comment Share on other sites More sharing options...
HostOrca Posted August 29, 2009 Share Posted August 29, 2009 Login to you admin area go to configuration >> general settings at the bottom of the page unselect the down for maintenance option, then save. 0 Quote Link to comment Share on other sites More sharing options...
DedicatedPros Posted August 29, 2009 Share Posted August 29, 2009 That looks to me like a MySQL username/pass/database name error Did you mess around with those settings recently? Unless of course its what Gareth suggested 0 Quote Link to comment Share on other sites More sharing options...
herpherp Posted August 29, 2009 Share Posted August 29, 2009 Also Make sure you delete install folders... 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted August 31, 2009 Administrators Share Posted August 31, 2009 This means the version of your files doesn't match the version of your database. You must have changed something recently, it can't happen by itself. 0 Quote Link to comment Share on other sites More sharing options...
RMIGHTY1 Posted December 29, 2010 Share Posted December 29, 2010 (edited) This means the version of your files doesn't match the version of your database. You must have changed something recently, it can't happen by itself. NEVERMIND, I FOUND THE MOST RECENT DB BACKUP, TY ) John, I have the same problem after restoring to an earlier database. The database I thought was the same version as the v4.4.1 files but apparently not as I looked for version numbers in the db to change them. I changed v.4 in tbladmin to v.4.4.1 and v.3.4.1 to v.4.4.1 in tblconfiguration but still no success. Can you please tell me where to change the version number in the database to match the file version? Thank you!!! Ray Snarski Edited December 29, 2010 by RMIGHTY1 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted December 30, 2010 Administrators Share Posted December 30, 2010 Changing the version number won't work as the actual contents of the database still won't match what the php files are expecting. You need to run through the proper upgrade process to update your database as described @ http://wiki.whmcs.com/Upgrading 0 Quote Link to comment Share on other sites More sharing options...
RMIGHTY1 Posted December 31, 2010 Share Posted December 31, 2010 Thank you John. I found a more recent backup of the db that I restored and it is now working just fine. Thank you again. 0 Quote Link to comment Share on other sites More sharing options...
