mesas Posted August 17, 2009 Share Posted August 17, 2009 Hi, everthing just work fine with WHMCS, but before few days I have this error when try to send email my customers. No Recipients The criteria selected for this email has resulted in no recipients which means it cannot be sent I use: Centos + Cpanel + WHMCS v. 3.8.1 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted August 17, 2009 Administrators Share Posted August 17, 2009 Hi, How are you sending this email, are you using the mass mail function? 0 Quote Link to comment Share on other sites More sharing options...
mesas Posted August 18, 2009 Author Share Posted August 18, 2009 CLIENTS PROFILE > Summary > Send Email or Email tab SEND MESSAGE > WHMCS allready fill: From: To: I write subject and text, try to send, but have this error. 0 Quote Link to comment Share on other sites More sharing options...
cyfered6 Posted August 18, 2009 Share Posted August 18, 2009 Did you change something in your settings before that?? 0 Quote Link to comment Share on other sites More sharing options...
mesas Posted August 18, 2009 Author Share Posted August 18, 2009 No, settings for WHMCS are same like before. 0 Quote Link to comment Share on other sites More sharing options...
afia Posted August 14, 2011 Share Posted August 14, 2011 I m using website panel (dotnetpanel) an i also facing same 0 Quote Link to comment Share on other sites More sharing options...
afia Posted August 14, 2011 Share Posted August 14, 2011 he criteria selected for this email has resulted in no recipients which means it cannot be sent. So, how can i add recipients there? 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted August 15, 2011 Administrators Share Posted August 15, 2011 It means no recipients meet the criteria you selected on the mass mail page. Try selecting different criteria. Post a screenshot of the criteria you select. 0 Quote Link to comment Share on other sites More sharing options...
prooi Posted September 23, 2011 Share Posted September 23, 2011 I have the same issue as the first poster with my Mass-Mailer. Here is what I pick: Email type: General Client group: Customer Language: Default,Danish,English Client Status: Active,Inactive,Closed And the error: No Recipients The criteria selected for this email has resulted in no recipients which means it cannot be sent arises. How to fix this? 0 Quote Link to comment Share on other sites More sharing options...
prooi Posted September 23, 2011 Share Posted September 23, 2011 Nevermind, i fixed it. It was due to not having any customers in the group named customers, so I created a hook to do it If anyone wants the hook, here it is: <?php function add_user_to_group($vars) { mysql_query("UPDATE tblclients SET groupid = 2 WHERE id = ". $vars['userid'] .""); } add_hook("ClientAdd",1,"add_user_to_group"); ?> This of course needs your default group to have the id 2. 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted September 26, 2011 Administrators Share Posted September 26, 2011 Alternatively leave the "Group" filter blank and clients who aren't in any group will be selected. 0 Quote Link to comment Share on other sites More sharing options...
