avizeke Posted July 30, 2009 Share Posted July 30, 2009 Hello all. i am looking for some help mainly in custom fields and custom pages. i basically want JUST my products page showing just the products and not the side bar. this is my 1st time venturing into whmcs files, am aware of html and have dream wever so i can undersatnd code but whmc looks overly complex. So if its possible for anyone to assist in a small understanding of how to remove and maybe some advise in undersatnding it. it would be appreciated. kindest regards zeke 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted July 30, 2009 WHMCS Product Manager Share Posted July 30, 2009 You'll need to edit the header.tpl and footer.tpl files in /templates/portal. With HTML knowledge you should be fine 0 Quote Link to comment Share on other sites More sharing options...
avizeke Posted July 30, 2009 Author Share Posted July 30, 2009 thanks john for your reply. i checked previous HOW TO's in forum, for the infor of header and footer. brought them up in dream wever, and the specific files i needed to edit were NOT there. for example this is the Footer.tpl yet the code that is needed to be edited is NOT there </td></tr></table> </td></tr></table> <table width="100%" border="0" cellpadding="0" cellspacing="0" class="footerbar"> <tr><td><table width="950" border="0" cellpadding="0" cellspacing="0" align="center"><tr><td><strong>{$companyname}</strong></td><td><div align="right">{if $langchange}{$setlanguage}{/if}</div></td></tr></table></td></tr> </table> </body> </html> Please if you can, which i appreciate, to elaberate some step by step, kindest regards zeke 0 Quote Link to comment Share on other sites More sharing options...
avizeke Posted July 31, 2009 Author Share Posted July 31, 2009 still waiting on a re response from this 0 Quote Link to comment Share on other sites More sharing options...
Impact-John Posted July 31, 2009 Share Posted July 31, 2009 what do you want to remove exactly and where from screenshots may help us out to help you 0 Quote Link to comment Share on other sites More sharing options...
avizeke Posted August 2, 2009 Author Share Posted August 2, 2009 i want to specifically remove, the left panel. and just have teh products showing. that means no banner, no nav bar, JUST the procucts website/whmcs/cart.php basically am gonna put product page in a iframe. were it just shows the products. i have added you to msn, for little assistance, again any help is appreciated. thanks. 0 Quote Link to comment Share on other sites More sharing options...
