Problem using API (IP Not Valid, SSL Problem?)
CrimsonGT
Everytime I try and use the API I get the same error message that popsup. I was trying to use the code posted by Matt on these forums for doing a order page using the API. When I fill it out and continue, I get this error. Ive gotten it a few other times trying to use the API as well.
Im wondering if its because I dont have SSL setup? Im on a shared webhost that charges quite a bit extra a month just for SSL so I dont have it.
Error Message
An error occured. Please contact support. (Invalid IP 8.8.246.46)
I have what looks to be Shared SSL, but ive never used SSL before so I have no clue on it.
Error Message
Log in to your WHMCS admin section, go to "General Settings". Click the "Other" tab. Is 8.8.246.46 listed in the "API IP Access Restriction" field? If not, add it there.
Ah thank you very much! I had no clue about that.
Im getting "An error occured. Please contact support. ()" now though. If anyones managed to get a working remote orderform and wouldnt mind sharing it I would greatly appreciate it.
  • 1 month later...
  • 8 months later...
