IP Monitor Admin Addon
Matt
I would like to give this addon a try, but the link to the zip file (http://support.whmcs.com/dl.php?type=d&id=32) returns a 404 "The requested URL /dl.php was not found on this server.".
Anyone know the valid location of the file?
TIA
edit:
Nevermind, the answer is: Utilities -> Addon Modules -> IP Monitor.
I guess my question now becomes: Should the module be removed from the Module user contribution section of the wiki, or should the link to the zip file be fixed?
Given that it's now part of the software package, is it still considered a user contribution?
Edited by chriss
clickety click.
  • 4 months later...
  • 4 weeks later...
  • 4 weeks later...
can I have request for allowing using different than default email SMTP server? I want to WHMCS to use my default SMTP server but I'm also monitoring it using IP Monitor and when he will go down then IP Monitor can't send email using this server :).
Thanks
