shed Posted March 10, 2008 Share Posted March 10, 2008 Problem: Kayako and WHMCS are both set tu use iso-8859-1 charset and work fine apart from each other..., however when I integrate WHMCS I get weird characters replacing my norwegion international characters in my Kayako support interface and tickets... anyone experienced anything similar? any ideas? Any help much appreciated! Rgds Terry Thorpe 0 Quote Link to comment Share on other sites More sharing options...
mylove4life Posted March 10, 2008 Share Posted March 10, 2008 not that I have seen, best bet would be to ask at the Kayako forum for that one... 0 Quote Link to comment Share on other sites More sharing options...
shed Posted March 10, 2008 Author Share Posted March 10, 2008 As it relates to WHMCS and Kayako I figured I would have twice the chance of solving this issue by posting on both forums... 0 Quote Link to comment Share on other sites More sharing options...
shed Posted March 14, 2008 Author Share Posted March 14, 2008 Well I finally got a solution to this... But not from Kayako... got to say a huge THANK YOU! to Ronnie Fang of hostingskin.com! Ronny supplied me with my (awesome)WHMCS template and after seeing I was having problems very kindly offered to make everything work... turns out WHMCS prefers utf8, ronnie tweaked my template and Kayako/WHMCS setup and Bingo! Shame Kayako support werent as effective - but perhaps this was due to the problem being across systems... anyway I have a solution now and am a very happy puppy... and wouldn't hesitate to recommend Ronnie to anyone experiencing similar issues, extremely friendly and helpful guy. Thanks Ronnie. 0 Quote Link to comment Share on other sites More sharing options...
shed Posted March 14, 2008 Author Share Posted March 14, 2008 P.S. My Integration is at https://www.shed49.com/billing/whmcs/clientarea.php 0 Quote Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2008 Share Posted June 5, 2008 We're having a similar problem. Customer raised a ticket via Kayako(WHMCS) and put a subject of 'FTP Query – Urgent' but when received via email; FTP Query liA=Urgent and then when viewed in Kayako staff area, appears as a ? symbol on a black square. � At a loss on this one so any suggestions are appreciated. 0 Quote Link to comment Share on other sites More sharing options...
Brett Posted June 5, 2008 Share Posted June 5, 2008 Go to Configuration -> General Settings and click the Localisation tab. You will see System Charset, change the iso-8859-1 to utf-8. That should fix the problems that you are having. 0 Quote Link to comment Share on other sites More sharing options...
shed Posted October 8, 2009 Author Share Posted October 8, 2009 No, it doesn't for us. 0 Quote Link to comment Share on other sites More sharing options...
