The GodFather Posted February 18, 2008 Share Posted February 18, 2008 Hello, I was just surfing around and landed here: http://www.whmcs.com/flashtutorials-whm.php None of the tutorials listed on the page works. When you click on it an new window opens and displays the following: Not FoundThe requested URL /tutorials/whm10_x_accesskey.html was not found on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. Apache/1.3.39 Server at whmcs.com Port 80 Link to comment Share on other sites More sharing options...
Arhineus Posted February 18, 2008 Share Posted February 18, 2008 I'd suspect they're still working on building it. If you check any of the links, you'll see that they aren't targeted at any specific files. Link to comment Share on other sites More sharing options...
bear Posted February 18, 2008 Share Posted February 18, 2008 I'd suspect they're still working on building it. If you check any of the links, you'll see that they aren't targeted at any specific files. Actually, they are. The "#" in the link is to anchor the href so it can pop up a window. The actual link is like this: <a href="#" onClick="window.open('tutorials/whm10_x_create.html','','width=796,height=468');return false"> Note the proper URL right at the start? The page or directory is missing, but the links are correct. Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted February 18, 2008 WHMCS CEO Share Posted February 18, 2008 We shouldn't have a link to that page anywhere on our site as far as I'm aware - it's just a page that's been left up there. The link now is http://www.whmcs.com/flashtutorials.php Matt Link to comment Share on other sites More sharing options...
bear Posted February 22, 2008 Share Posted February 22, 2008 Since this was explained already, no need for further comments. </thread> Link to comment Share on other sites More sharing options...
