FastLane Posted May 13, 2024 Share Posted May 13, 2024 I purchased this theme BlueCheap Host WHMCS Theme from redcheap and it doesn't seem to work properly on my Hosting server. I wanted to see if someone knows what are the requirements my server needs to have so that it works as it should. I have root access to the WHM in case if its a module i dont know about. I asked in a support ticket in the RedCheap site and they don't seem to know either. 404 - Page Not Found - FastLane Servers it works perfectly on my other hosting account that i don't have access to root but in my VPS that I do have access it doesn't. If someone knows the requirements for it to work please help me out. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Technical Analyst II WHMCS SamP Posted June 4, 2024 WHMCS Technical Analyst II Share Posted June 4, 2024 Hi @FastLane, Most template vendors will include a readme file or an installation guide that you can follow to configure the template. I don't believe server requirements are an issue here. As long as WHMCS is installed and configured properly, you should be good to go. When you say it's not working properly, what exactly is not working? Sam 0 Quote Link to comment Share on other sites More sharing options...
