nimafire Posted May 2, 2024 Share Posted May 2, 2024 hello ive got this error on upgrade from 8.8 to 8.10 SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'as `s` where `s`.`task_id` = ?' at line 1 (SQL: delete from `tbltask_status` as `s` where `s`.`task_id` = 35) 0 Quote Link to comment Share on other sites More sharing options...
Vox Posted May 3, 2024 Share Posted May 3, 2024 Hi @nimafire, Have you tried this: https://help.whmcs.com/m/v810/l/1799451-sqlstate-42000-syntax-error-or-access-violation-1064-error 1 Quote Link to comment Share on other sites More sharing options...
Evolve Web Hosting Posted May 21, 2024 Share Posted May 21, 2024 @nimafire are you using the 8.10.1 download? Did the upgrade process itself complete with no errors? Which page are you seeing the error you mentioned? 0 Quote Link to comment Share on other sites More sharing options...
