Hide Payment Method section for Free Trial products
Craft
I'm offering a Free Trial period for my web hosting service, so when the customer goes to the Checkout page, he sees the Total price is $0.00  and he should select the payment method (Credit Card) or (PayPal), so he thoughts that we gonna charge him or trick him, so he refuses to continue!
How can I hide the Payment section when the Total price is $0.00?
1 hour ago, AladdinJ said:
I have made this hook for you now
try it and tell me if works with you
First of all, I would like to thank you for your time and effort 🙂
The payment options (Credit Card / PayPal) became hidden, but the credit card fields still exist.
Can you force selecting the payment method (PayPal) before hiding the payment section? I think this issue will be solved if you did that.
Edited by Craft
also I have made a way as You mentioned
selecting PayPal then Hide the Payment Gateways Only
add_hook('ClientAreaPageCart', 1, function($vars) {
    if ($vars['rawtotal'] == 0.00)
        add_hook('ClientAreaFooterOutput', 1, function($vars) {
        $v = "input[value='paypal']";
        $return = '
<script>
    document.querySelector("'.$v.'").checked = true;
    const PGC = document.getElementById("paymentGatewaysContainer");
    PGC.style.display = "none";
        return $return;
you can try any one you like
I left the both ways in the file
43 minutes ago, AladdinJ said:
you are right , I have updated it now
I made it wait 1 second before hide the elements , that fixed the problem
This version hides the payment methods but the issue that it's still reading the credit card fields and still asking us to fill up the mandatory fields
        $return = '
<script>
        return $return;
This version hides some of credit card fields, but not hiding the payment methods
if you are using paypalcheckout module
you shoud repleace that in the code in the $v
I have edited it for you
        $v = "input[value='paypalcheckout']";
        $return = '
<script>
</script>
        return $return;
try and tell me if it works
Edited by AladdinJ
I was missing </script> , fixed now
The 2nd version in the github hides the payment methods but the issue that it's still reading the credit card fields and still asking us to fill up the mandatory fields
Yes, I realized that hiding credit card will not be useful, as entering the card details is mandatory,
so I commented that code
but as you mentioned choosing PayPal was a good idea
I made it in the last reply from me or the first code on GitHub
try and tell me if that works with you
        $return = '
<script>
</script>
        return $return;
I tried this code and changed the payment name to (paypal) and (paypalcheckout), but it doesn't work.
The output is in this screenshot
  • 3 weeks later...
Hi Aladdin,
I'm trying to do the exact same thing.  My payment gateway is named "Credit Card" but when I use that in this line it doesn't do anything.  I see in your code to "select payment method other than credit card" not sure what to do as I don't use PayPal.
$v = "input[value='Credit Card']";
My product is set to $10 and I'm using a Promo Code with a $10 value so the cart is $0
Thanks!
1 hour ago, FutureX said:
Hi Aladdin,
Thanks!
try this hook
        $return = '
<script>
    setTimeout(function(){
        const CCIF = document.getElementById("creditCardInputFields");
        CCIF.style.display = "none";
}, 1000);
</script>
        return $return;
try to continue placing the order not just see the section hides
tell me if it works or if got problems
Thanks for the help!
I added the new hook.  The payment section hides except for the section title "Payment Method" I'm using the Lagom 2 theme.
Total Due Today is $0, when I hit checkout it tries to run and then stops with no error message and no order completion.
you have any other payment gate other than credit card, as I think it's require to enter card deatils ,so if we heddin it will get an error or not be able to compte order
if you hava another payment gate way ,, then we may let code swith to it , and hide the section of payment methods
4 minutes ago, FutureX said:
I don't have any other payment method right now, but I can setup a PayPal account just for this.
So if the cart total is $0 then the hook will switch the payment method to PayPal and then hide it?
Sounds great.
yes exaclty ,, any way I will try to check if there is anyway using only credit card payment method , I will tell you I rech to solution
