Self split invoices or never merge products
jmginer
Hello, is either of these two options available?
- In an invoice with several products, the customer can "split" a product by himself without having to contact the admin.
- That the products of a customer, never make "merge" and always generate individual invoices for each product.
Thank you!
Thank you!
1. No, this has to be done by the admin. A customer cannot split invoices on its own. At least not by default since this would involve creating a new invoice. It can probably be done manually with custom coding some hooks and API's.
2. Yes, there is a setting in the customer profile called Separate Invoice that does that.
