cyberneticos Posted December 18, 2007 Share Posted December 18, 2007 The Integration is far from finished. Kayako still needs to weed out some bugs. Some pretty big bugs. Possibly by the end of this week or next a new kayako stable release will be out with a stable version of the integration. Follow here --> http://forums.kayako.com/f56/support-suite-integration-whmcs-merged-14755/ 0 Quote Link to comment Share on other sites More sharing options...
Calinax Posted December 19, 2007 Share Posted December 19, 2007 I've a problem here. When I click Port Reply to a ticket using whmcs/kayako integration, the button disappears and nothing happens. How do I fix this? KayKao support is very lazy, 5 days and still I don't know the direction where they're leading the ticket to. 0 Quote Link to comment Share on other sites More sharing options...
cyberneticos Posted December 22, 2007 Author Share Posted December 22, 2007 They are currently working on it,. and from what I can see and test, they are almost done. I am testing with CVS versión. One thing I do notice is that when using the Portal template, the vertical menu takes up so much space that it deforms kayako tables completely. What is supposed to be on one line turns into like 3 in some cells. Also the CSS changes a little bit, but I think that is a bug they are working on too. Not sure. 0 Quote Link to comment Share on other sites More sharing options...
DataHosts Posted December 29, 2007 Share Posted December 29, 2007 Wow..just tried to Kayako integration. 1) I am unable to select Kayako from the support dropdown within WHMCS 2) the Kayako loginshare for WHMCS is blank with no possible fields to fill Guess I will try again later 0 Quote Link to comment Share on other sites More sharing options...
arcdigital Posted December 31, 2007 Share Posted December 31, 2007 1) I am unable to select Kayako from the support dropdown within WHMCS You need to upload the kayako support module from the kayako cvs package. It's in there 2) the Kayako loginshare for WHMCS is blank with no possible fields to fill I'm pretty sure everyone's is like that right now. (Mine is) 0 Quote Link to comment Share on other sites More sharing options...
cyberneticos Posted December 31, 2007 Author Share Posted December 31, 2007 Kayako Integration Progress: http://forums.kayako.com/f56/support-suite-integration-whmcs-merged-14755/index12.html#post68393 0 Quote Link to comment Share on other sites More sharing options...
Calinax Posted January 1, 2008 Share Posted January 1, 2008 We'rent going to see before 2009, probably. Kyakjo is going WORST! Previous releases were like every 1-2 months but this one has already used up July-continued... 0 Quote Link to comment Share on other sites More sharing options...
cyberneticos Posted January 1, 2008 Author Share Posted January 1, 2008 Naw man,... The bugs with whmcs integration are the next ones on the list. I'm sure it won't be long before they fix at least the mayor bugs, which shouldn't be hard bugs to fix. I think we'll have it sometime this week. 0 Quote Link to comment Share on other sites More sharing options...
DataHosts Posted January 2, 2008 Share Posted January 2, 2008 Ok...makes me feel better. Yea..uploaded the module from the CVS, and the dropdown was there. In the first download the /integrate folder was not included...strange. According to Jamie Edwards (kayako) the CVS tonight will address bugs to get WHMCS working with Kayako properly. This is the link 0 Quote Link to comment Share on other sites More sharing options...
DeanClinton Posted January 2, 2008 Share Posted January 2, 2008 But... it's still a CVS build We are still "beta" testing Kayako's product. 0 Quote Link to comment Share on other sites More sharing options...
DataHosts Posted January 2, 2008 Share Posted January 2, 2008 I agree...but I just wanted others to be aware. 0 Quote Link to comment Share on other sites More sharing options...
DataHosts Posted January 3, 2008 Share Posted January 3, 2008 Well..guess what...I am still unable to get Kayako to work properly. So, i am done with kayako until CVS becomes stable, and others get it to work. WHMCS built in HD will work fine. 0 Quote Link to comment Share on other sites More sharing options...
hobbit666 Posted January 3, 2008 Share Posted January 3, 2008 OK so i'm one of many people waiting for this to be finished which i looks like it's close to be. but the latest on the kayako forum is The latest CVS is already in a code freeze state, apart from 2-3 bug fixes it will be marked as stable once the WHMCS issue is resolved so Matt what's the WHMCS issue and when will you have a fix for them? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted January 3, 2008 WHMCS CEO Share Posted January 3, 2008 That's the first I've heard of any issue on our side. You'll have to get some more information from them as they haven't contacted us relating to anything - ALL the issues so far have been on their side. My understanding of that comment is that they have an issue with the WHMCS integration - not us. Matt 0 Quote Link to comment Share on other sites More sharing options...
hobbit666 Posted January 3, 2008 Share Posted January 3, 2008 hi Matt here is the other part of that thread As for the client area not showing any open tickets, The integration code supplied by WHMCS does not allow us to override the clientarea.php, I will email Matt and see if its a possibility that he can implement this for us but it is entirely upon them to finish this part. We have completed the integration for every section that we were provided access to (Which specifically deals with support aspects of their product and not the clientarea.php) I know it says "I will E-mail Matt" but the way and speed they are running at it'll be next year. Can i ask you contact them ASAP 0 Quote Link to comment Share on other sites More sharing options...
Brett Posted January 3, 2008 Share Posted January 3, 2008 You can always remove the open tickets code from the clientareahome.tpl That is what I have done. 0 Quote Link to comment Share on other sites More sharing options...
Chrisw Posted January 3, 2008 Share Posted January 3, 2008 Wouldn't it be nice to have a section to display open, on hold, and awaiting response? over a some time the is ticket list can get rather larger. What if a ticket is reopened later on.. will it be open on page5 out of easy reach? 0 Quote Link to comment Share on other sites More sharing options...
Brett Posted January 3, 2008 Share Posted January 3, 2008 Chrisw, I believe that all of those functions are controlled in the admin section of kayako. Just go to your admin section of kayako then go to Settings -> Tickets. You will be able to edit the options there. 0 Quote Link to comment Share on other sites More sharing options...
Chrisw Posted January 3, 2008 Share Posted January 3, 2008 Brett, I know what you mean (at least for the admin side), but I'm hoping to mimic the view as Matt implemented it. This would keep things clean and more organized and prevent a big pile-up just my 2cents.. 0 Quote Link to comment Share on other sites More sharing options...
Brett Posted January 3, 2008 Share Posted January 3, 2008 Oh, ok well then I have a solution for you! <{displaytemplate name="header"}> <p><strong>Support Tickets</strong> (<a href="submitticket.php">Submit Ticket</a>)</p> <table align="center" style="width:100%" class="clientareatable" cellspacing="1"> <tr class="clientareatableheading"><td>Ticket ID</td><td>Subject</td><td>Date</td><td>Department</td><td>Status</td><td>Urgency</td></tr> <{foreach key=key value=ticket from=$ticketlist}> <tr class="clientareatableactive"><td><a href="<{if $iswhmcs==true}>viewticket.php?<{else}><{$baseurl}><{/if}>_m=tickets&_a=viewticket&ticketid=<{$ticket[ticketid]}>"><{$ticket[fticketid]}></a></td><td><div align="left"><img src="images/support/article.gif" hspace="5" align="middle" alt="" /><a href="<{if $iswhmcs==true}>viewticket.php?<{else}><{$baseurl}><{/if}>_m=tickets&_a=viewticket&ticketid=<{$ticket[ticketid]}>"><strong><{$ticket[subject]}></a></div></td><td><{$ticket[lastactivity]}></td><td><{if $ticket[department] == 'private'}><{$language[private]}><{/if}><{if $ticket[department] != 'private'}><{$ticket[department]}><{/if}></td><td width="120"><font color="<{$ticket[statuscolor]}>"><{if $ticket[status] == 'private'}><{$language[private]}><{/if}><{if $ticket[status] != 'private'}><{$ticket[status]}><{/if}></font></td><td width="80"><font color="<{$ticket[prioritycolor]}>"><{$ticket[priority]}></font></td></tr> <{foreachelse}> <tr class="clientareatableactive"><td colspan="6">No Tickets currently open</td></tr> <{/foreach}> </table> <{displaytemplate name="footer"}> You will need to paste this in the templates -> tickets -> ticketlist in your SupportSuite admin. Just paste the code there. What will happen is the last reply to the ticket will go up top. That shows it to be a lot like what is in the original portal theme. 0 Quote Link to comment Share on other sites More sharing options...
Chrisw Posted January 3, 2008 Share Posted January 3, 2008 Thanks Brett, I'll give is a shot in a few 0 Quote Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2008 Share Posted January 5, 2008 Hi, I've had this WHMCS/Kayako integration working since before Christmas. It is abit tricky but it works fine. The only issue I have is with downloads but that appears to be a bug. The CVS version from Kayako released a few days ago that should 'work', still works and gave us no problems or additional features over the first release. It is possible - just persistence I guess. 0 Quote Link to comment Share on other sites More sharing options...
Chrisw Posted January 5, 2008 Share Posted January 5, 2008 hehe, it it works fine for you... you havnt messed with it enough! To fix your download issue; In /whmcspath/modules/support/kayako/download.php (line 9) find $_REQUEST["_a"] = "viewdownload"; $_GET["_a"] = "viewarticle"; $_POST["_a"] = "viewarticle"; and replace with $_REQUEST["_a"] = "viewdownload"; $_GET["_a"] = "viewdownload"; $_POST["_a"] = "viewdownload"; or simply change the instances of "viewarticle" to "viewdownload" in that line 0 Quote Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2008 Share Posted January 5, 2008 I have Honest.. Involved loads of changes here and there with our own setup - which is annoying as I liked having things seperate. Also found out if you delete/rename the language English (UK) in Kayako, things go missing - bit of a bug there (even if you have another language selected). Cheers for the tip! Much appreciated (and works well). We also hacked around the WHMCS templates to pull ticket info from the Kayako database for the logged in user. Pics attached. Matt 0 Quote Link to comment Share on other sites More sharing options...
getweb Posted January 8, 2008 Share Posted January 8, 2008 We also hacked around the WHMCS templates to pull ticket info from the Kayako database for the logged in user.Pics attached. Something ugly like this? This is beta code, and I've never used SMARTY before, but if it helps somebody, great. (EDIT: By the way, I based the userid/API lookups on what a query log showed Kayako actually doing with WHMCS... it should be close to correct. Also, great to see the integration between them is NOT email address dependent!) While editing "clientareahome.tpl" replace the Support Tickets table with: {php} // It is probably not wise to put this here, but kind of a pain // to put anywhere else and call from template // Consider making a special read-only SQL user for this purpose? $kayakoHost = "localhost"; $kayakoUser = "dbuser"; $kayakoPass = "dbpass"; $kayakoDB = "dbname"; $kDB = mysql_connect($kayakoHost,$kayakoUser,$kayakoPass); if ($kayakoDB) mysql_select_db($kayakoDB,$kDB); else print '<p align="center" style="color: #CC0000">NOTE: Could not access ticket database.</p>'; // First, get the WHMCS user id $arrdetails = $this->get_template_vars('clientsdetails'); $whmcsID = $arrdetails['userid']; $kayakoID = ""; // Look up Kayako's userid searching the API userid field for the WHMCS id // Correct - this is not email based! if ($kDB) { $result = mysql_query("SELECT userid FROM swusers WHERE loginapi_moduleid = '300' AND loginapi_userid = '$whmcsID'",$kDB); $row = mysql_fetch_row($result); $kayakoID = $row[0]; } if ($kayakoID > '') { // Now, find the email address for this user (see why shortly) $result = mysql_query("SELECT email FROM swuseremails WHERE userid = '$kayakoID'",$kDB); $row = mysql_fetch_row($result); $kayakoEmail = $row[0]; // Finally, get the tickets based on email NOT by userid // This is because tickets can have multiple emails, and therefore users... (right?) // This may need revision or to hide closed tickets - I decided to show them $result = mysql_query("SELECT tickets.ticketid,tickets.lastactivity,tickets.ticketmaskid,tickets.subject," . "depts.title AS dept,status.title AS status,prio.title AS priority FROM swtickets tickets " . "LEFT JOIN swdepartments depts ON depts.departmentid = tickets.departmentid " . "LEFT JOIN swticketstatus status ON status.ticketstatusid = tickets.ticketstatusid " . "LEFT JOIN swticketpriorities prio ON prio.priorityid = tickets.priorityid " . "WHERE email IN ('$kayakoEmail') ORDER BY lastactivity DESC LIMIT 5", $kDB); if ($result) while ($row = mysql_fetch_array($result)) { $row["date"] = strftime("%d %b %Y %I:%M %p",$row["lastactivity"]); $this->append('tickets', $row); } } {/php} <table align="center" style="width:90%" class="clientareatable" cellspacing="1"> <tr class="clientareatableheading"><td>{$LANG.supportticketsdate}</td><td>{$LANG.supportticketssubject}</td> <td>{$LANG.supportticketsstatus}</td><td>{$LANG.supportticketsticketurgency}</td><td>Department</td></tr> {foreach key=cid item=ticket from=$tickets} <tr class="clientareatableactive"><td>{$ticket.date}</td> <td><div align="left"><img src="images/support/article.gif" hspace="5" align="middle" alt="" /><a href="viewticket.php?_m=tickets&_a=viewticket&ticketid={$ticket.ticketid}">#{$ticket.ticketmaskid} - {$ticket.subject}</a></div></td> <td width="60">{$ticket.status}</td> <td width="60">{$ticket.priority}</td> <td width="120">{$ticket.dept}</td></tr> {foreachelse} <tr class="clientareatableactive"><td colspan="5">{$LANG.supportticketsnoopentickets}</td></tr> {/foreach} </table> 0 Quote Link to comment Share on other sites More sharing options...
