Need a hook for changing a div class
Using the hook in
and just adding in
 $('#inputOptionXX').parent().parent().attr('class', 'col-sm-12');
to the html string should do the trick.  You just need to get the input field name for that option.   However, do note that you will probably have to adjust the other input also as otherwise you will get a blank area there.
Hello, below did the trick by product, because some products configOptions are different from others. Only thing you can select more than one products inserting product id into array in $products like 3,5,10 that has same inputConfigOption value. Appreciate for your help
<?php
add_hook('ClientAreaFooterOutput', 1, function ($vars) {
    // Add the product ID to the array below with commas separting them.  For example: array(1,4,5)
    $Products = array();
    if (isset($vars['templatefile']) and $vars['templatefile']==='configureproduct')
        if (isset($vars['productinfo'] ) and in_array($vars['productinfo']['pid'], $Products))
            $HTML = "<script>
            $( document ).ready(function() {
                  $('#inputConfigOption19').parent().parent().attr('class', 'col-sm-12'); });
            </script>";
            return $HTML;
If you want that to apply to any product that has that config option, just remove the if that checks for product.  The id for that config option will be the same for any other product.
