Required Some Design Help On Custom Hook
natanray
I am using a custom support pin hook in WHMCS. The code is below:
<?php
use WHMCS\View\Menu\Item as MenuItem;
add_hook('ClientAreaPrimarySidebar', 1, function (MenuItem $primarySidebar)
  $client = Menu::context('client');
  if (!is_null($client)) {
$SupportPIN = generatePinCode($_SESSION['uid'], 5);
  $primarySidebar->addChild('Support-Pin', array(
        'label' => "Support Pin",
        'uri' => '#',
        'order' => '1',
        'icon' => 'fa-key'
  $primarySidebar->getChild('Support-Pin')->setBodyHtml($SupportPIN);
add_hook('AdminAreaClientSummaryPage', 1, function($vars) {
    return 'Support Pin: ' . generatePinCode($vars['userid'], 5);
function generatePinCode($clientid = 0, $length = 6){
    $clientid = intval($clientid);
    preg_match_all('!\d+!', md5(date("y" . $clientid)), $matches);
    $numbers = join("", $matches[0]);
    return substr($numbers, 0, $length);
This code is giving below UI in our WHMCS clientarea. (Pic: Screenshot (292).png)
But I would like to show the Support Numbers in the another screenshot format. Like some boxes around the numbers and just a copy option right side.
then you could always buy the addon module that generates that screenshot from Marketplace  - it's only $15 and i'm sure @string would appreciate it! 🎁
visually, it's just restyling the PIN content of the body with CSS or images; and then adding a footer that contains clipboard copy, recycle and help button functionality.
technically, that's not complicated to do, but I see no point in reinventing the wheel and potentially damaging income to a developer, when they have already spent time coding what you want to do.
just because I know how to do what you want, doesn't mean that I need to or, more importantly, should tell you.... buy the addon! headshake.gif
