Can it be possible to display a product's Triennially price in monthly breakdown price using pricing feed code
Hello there,
Suppose my product price is
30/monthly
75/quarterly
120/semiannually
180/annually
$360/triennially.
If I want to display   in my html page the monthly cheapest price , I will take the option of triennially price . Generally I can use
<script language="javascript" src="feeds/productsinfo.php?pid=5&get=price&billingcycle=triennially&currency=1"></script>
But it need to display that price by monthly breakdown i.e. 10/month by using product pricing feed code.
How can change the pricing feed code?
firstly, don't edit productsinfo.php as it would get overwritten during an update - so duplicate it and modify the copy and that should be safe from updating.
in the code there should be...
    $price = $data->$billingCycle;
after it, just add...
	if ($billingCycle = "triennially") {
		$price = number_format(($price / 36), 2);;
when you pass "triennially" in the feed URL, then it should return a breakdown price for that cycle...
obviously, this can be expanded for the other cycles (just be modifying the division number, e.g 36, 24, 12, 6 etc) and you could expand it further to give you the option of returning the triennial amount, or a breakdown amount.
