Admin V4 Theme System Settings showing incorrectly
14 hours ago, Louis Switch My Server said:
Anyone had this issue or know how to fix it?
short-term, you could fix this with Admin Language Overrides as I mentioned in the post below about using the v7 Blend template - the same would apply to using v4...
<?php
$_ADMINLANG['setup']['title'] = "Setup";
$_ADMINLANG['help']['support'] = "Get Help";
11 hours ago, Louis Switch My Server said:
Is there only blend theme now then?
only Blend is shipped now, but I imagine v4 would still more or less work for the next few releases  - the menu links should still work (I assume), but how some of the newer pages are handled, might not be ideal in v4.
btw - the default menu in v8 Blend is awful and i'm writing a hook to redesign it, or at least make is usable.. e.g make everything (more or less) accessible from the main menu and not requiring multiple clicks to get to your intended destination.
and before you ask, it's nowhere near finished and not imminent!
<?php
Thank you for this, this is really useful.
I'm not a fan of the v8 menu to be honest, I preferred hover over and clicking what I needed, seems like I need to do a lot more clicks and menus slightly different, takes some getting used to.
That hook will be great and a lot better than menu now. 🙂
  • 4 months later...
