Problem
Murias
I'm having this issue
What can i do to fix it?
Quote
TypeError: Argument 1 passed to Carbon\CarbonInterval::setLocalTranslator() must implement interface Symfony\Component\Translation\TranslatorInterface, instance of Carbon\Translator given, called in /var/www/html/billing/vendor/nesbot/carbon/src/Carbon/Traits/Difference.php on line 778 and defined in /var/www/html/billing/vendor/nesbot/carbon/src/Carbon/Traits/Localization.php:168
Stack trace:
#0 /var/www/html/billing/vendor/nesbot/carbon/src/Carbon/Traits/Difference.php(778): Carbon\CarbonInterval->setLocalTranslator(Object(Carbon\Translator))
#1 /var/www/html/billing/modules/widgets/Staff.php(37): Carbon\Carbon->diffForHumans()
#2 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Module/AbstractWidget.php(0): WHMCS\Module\Widget\Staff->generateOutput(Array)
#3 /var/www/html/billing/templates_c/77a5bba4adba1ac64ca02e7faf82fb89ff6a21c3_0.file.homepage.tpl.php(153): WHMCS\Module\AbstractWidget->render()
#4 /var/www/html/billing/vendor/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php(123): content_5f73a930a43756_20188795(Object(Smarty_Internal_Template))
#5 /var/www/html/billing/vendor/smarty/smarty/libs/sysplugins/smarty_template_compiled.php(114): Smarty_Template_Resource_Base->getRenderedTemplateCode(Object(Smarty_Internal_Template))
#6 /var/www/html/billing/vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php(216): Smarty_Template_Compiled->render(Object(Smarty_Internal_Template))
#7 /var/www/html/billing/vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(232): Smarty_Internal_Template->render(false, 0)
#8 /var/www/html/billing/vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(116): Smarty_Internal_TemplateBase->_execute(Object(Smarty_Internal_Template), NULL, NULL, NULL, 0)
#9 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Smarty.php(0): Smarty_Internal_TemplateBase->fetch('blend/homepage....', NULL, NULL, NULL, false, true, false)
#10 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Admin.php(0): WHMCS\Smarty->fetch('blend/homepage....')
#11 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Admin.php(0): WHMCS\Admin->output()
#12 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Admin/Controller/HomepageController.php(0): WHMCS\Admin->display()
#13 [internal function]: WHMCS\Admin\Controller\HomepageController->index(Object(WHMCS\Http\Message\ServerRequest))
#14 /var/www/html/billing/vendor/middlewares/utils/src/CallableHandler.php(26): call_user_func_array(Array, Array)
#15 /var/www/html/billing/vendor/middlewares/fast-route/src/FastRoute.php(96): Middlewares\Utils\CallableHandler::execute(Array, Array)
#16 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/HandleProcessor.php(0): Middlewares\FastRoute->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#17 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\HandleProcessor->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#18 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\HandleProcessor->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#19 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#20 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#21 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/DelegatingMiddlewareTrait.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#22 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Admin\ApplicationSupport\Route\Middleware\Assent->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#23 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#24 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#25 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/DelegatingMiddlewareTrait.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#26 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Security/Middleware/Authorization.php(0): WHMCS\Security\Middleware\Authorization->delegateProcess(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#27 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/AbstractProxyMiddleware.php(0): WHMCS\Security\Middleware\Authorization->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#28 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\AbstractProxyMiddleware->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#29 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\AbstractProxyMiddleware->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#30 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#31 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#32 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/DelegatingMiddlewareTrait.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#33 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/AbstractProxyMiddleware.php(0): WHMCS\Admin\ApplicationSupport\Route\Middleware\Authentication->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#34 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\AbstractProxyMiddleware->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#35 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\AbstractProxyMiddleware->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#36 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#37 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#38 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/DelegatingMiddlewareTrait.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#39 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Admin\ApplicationSupport\Route\Middleware\DirectoryValidation->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#40 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#41 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#42 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/BackendPsr7Response.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#43 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/BackendPsr7Response.php(0): WHMCS\Route\Middleware\BackendPsr7Response->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#44 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\BackendPsr7Response->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#45 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#46 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#47 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(56): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#48 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/BackendDispatch.php(0): Middlewares\Utils\Dispatcher->dispatch(Object(WHMCS\Http\Message\ServerRequest))
#49 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\BackendDispatch->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#50 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\BackendDispatch->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#51 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#52 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#53 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/RoutePathMatch.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#54 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\RoutePathMatch->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#55 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\RoutePathMatch->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#56 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#57 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#58 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/WhitelistFilter.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#59 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/DelegatingMiddlewareTrait.php(0): WHMCS\Route\Middleware\WhitelistFilter->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#60 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\WhitelistFilter->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#61 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#62 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#63 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/RoutableClientModuleRequest.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#64 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\RoutableClientModuleRequest->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#65 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\RoutableClientModuleRequest->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#66 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#67 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#68 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/RoutableAdminRequestUri.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#69 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\RoutableAdminRequestUri->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#70 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\RoutableAdminRequestUri->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#71 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#72 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#73 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/RoutableRequestUri.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#74 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\RoutableRequestUri->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#75 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\RoutableRequestUri->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#76 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#77 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#78 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/RoutableRequestQueryUri.php(0): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#79 /var/www/html/billing/vendor/whmcs/whmcs-foundation/lib/Route/Middleware/Strategy/AssumingMiddlewareTrait.php(0): WHMCS\Route\Middleware\RoutableRequestQueryUri->_process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#80 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(76): WHMCS\Route\Middleware\RoutableRequestQueryUri->process(Object(WHMCS\Http\Message\ServerRequest), Object(Middlewares\Utils\Delegate))
#81 [internal function]: Middlewares\Utils\Dispatcher->Middlewares\Utils\{closure}(Object(WHMCS\Http\Message\ServerRequest))
#82 /var/www/html/billing/vendor/middlewares/utils/src/Delegate.php(31): call_user_func(Object(Closure), Object(WHMCS\Http\Message\ServerRequest))
#83 /var/www/html/billing/vendor/middlewares/utils/src/Dispatcher.php(56): Middlewares\Utils\Delegate->process(Object(WHMCS\Http\Message\ServerRequest))
#84 /var/www/html/billing/admin/index.php(0): Middlewares\Utils\Dispatcher->dispatch(Object(WHMCS\Http\Message\ServerRequest))
#85 {main}
  • 2 months later...
  • WHMCS Product Manager
Hi there,
During the update to WHMCS 8 a number of files are deleted from the installation. However, if these fail due to permission issues certain files left over could cause issues. This particular issue you experienced appears to be caused by the following file not being able to be deleted:
/vendor/symfony/translation/TranslatorInterface.php
Therefore if you experience the issue after upgrade removing that file should solve the problem.
  • 1 year later...
Oops!
Something went wrong and we couldn't process your request.
Please go back to the previous page and try again.
For additional assistance, please reference the WHMCS TroubleShooting Guide »
TypeError: Argument 1 passed to WHMCS\Module\Server::buildServiceParams() must be an instance of WHMCS\Service\Service, null given, called in /home/clienttechit/public_html/vendor/whmcs/whmcs-foundation/lib/Module/Server.php on line 0 and defined in /home/clienttechit/public_html/vendor/whmcs/whmcs-foundation/lib/Module/Server.php:0
Stack trace:
#0 /home/clienttechit/public_html/vendor/whmcs/whmcs-foundation/lib/Module/Server.php(0): WHMCS\Module\Server->buildServiceParams(NULL)
#1 /home/clienttechit/public_html/vendor/whmcs/whmcs-foundation/lib/Module/Server.php(0): WHMCS\Module\Server->buildParams()
#2 /home/clienttechit/public_html/vendor/whmcs/whmcs-foundation/lib/Module/AbstractModule.php(0): WHMCS\Module\Server->call('MetaData')
#3 /home/clienttechit/public_html/vendor/whmcs/whmcs-foundation/lib/Module/AbstractModule.php(0): WHMCS\Module\AbstractModule->getMetaData()
#4 /home/clienttechit/public_html/vendor/whmcs/whmcs-foundation/lib/Module/Server.php(0): WHMCS\Module\AbstractModule->load('marketconnect')
#5 /home/clienttechit/public_html/admin/orders.php(0): WHMCS\Module\Server::factoryFromModel(Object(WHMCS\Service\Addon))
#6 {main}
This message show when I click pending order and go to accept order
