-M- Posted September 17, 2020 Share Posted September 17, 2020 Hi all, Is there a solution in hiding products completely from the admin interface with the status (Hidden) under "Products/Services"-section? There are quite an amount of products which are not used anymore (but I cannot delete them) which makes the products view page in the admin section really look unorganised. Maybe someone has a solution for this? I just want to get those products with (Hidden) gone from my view. Nothing else. Thanks in advance. Regards 0 Quote Link to comment Share on other sites More sharing options...
-M- Posted September 17, 2020 Author Share Posted September 17, 2020 Okay, small follow-up. I have found a work-around. Maybe useful for others as well. I created a new product group (named it something like "Various") and moved all "(Hidden)" products to that group. I also changed the following for each product to make sure that they could not be selected. Put them on stock control and stock at 0 Changed their status to "Retired" I also moved the new product group (Various) to the bottom of the page. Ofcourse they are still there, but my other product groups are better organised now. Sidenote; I would recommend to not change the name to something like "Old products" or similar as it would show up like this under the customer's panel. Therefor I used the term "Various" which would cause less questions asked obviously.But if someone has a hook to hide a certain product group (e.g. with ID 16 in my case), that would be sweet. Obviously this is not a real solution and only a simple workaround, but in my case it works good enough for the time being! I hope this helps others as well. Regards 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted September 17, 2020 Share Posted September 17, 2020 1 hour ago, MvdL1979 said: Maybe someone has a solution for this? I just want to get those products with (Hidden) gone from my view. Nothing else. hiding with CSS would certainly work - though with it being the admin area, you'd have to apply the CSS via a hook. 33 minutes ago, MvdL1979 said: But if someone has a hook to hide a certain product group (e.g. with ID 16 in my case), that would be sweet. you are now in possession of such a hook (replying to your PM) - along with an even better one that hides the products from the list automatically if they are marked as hidden/retired. 1 Quote Link to comment Share on other sites More sharing options...
-M- Posted September 18, 2020 Author Share Posted September 18, 2020 Thank you Brian!! 😄 0 Quote Link to comment Share on other sites More sharing options...
