ilovechinahk Posted June 5, 2020 Share Posted June 5, 2020 i want make sure it will auto send the renew invoice to my client. i saw a messge inside "setups" >>"Automation settnigs" : " The cron command below is provided for convenience. You should configure a cron task to run every 5 minutes using the command provided below within your server cron utility or web hosting control panel." Cron Command */5 * * * * /usr/bin/php -q /home/linkforecom/whmcsdata5685/crons/cron.php I didn't amend my cron job setting on server (everything is default setting) , my question is 1) the defaut setting currently set on the server is how many mins to cron ? 2) if i did not set it into 5 mins, what happen, will the renew invoice will not be auto sent? 3) i open the document of cron.php, i don't know put the "Cron Command */5 * * * *" to which line, can you assist. thanks all 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted June 6, 2020 Share Posted June 6, 2020 On 05/06/2020 at 09:59, ilovechinahk said: 1) the default setting currently set on the server is how many mins to cron ? I wouldn't consider there to be a default setting for a cron job - when you setup a cron, you can define how often it runs. On 05/06/2020 at 09:59, ilovechinahk said: 2) if i did not set it into 5 mins, what happen, will the renew invoice will not be auto sent? renewals invoices are only sent once per day anyway, so they should be sent when the cron next runs after the "time of Day" setting in the Automation Settings. https://docs.whmcs.com/Automation_Settings#Time_of_Day you don't really need to set it to 5 mins if you don't want to - very few features need to be checked that often, and especially if you aren't using them. On 05/06/2020 at 09:59, ilovechinahk said: 3) i open the document of cron.php, i don't know put the "Cron Command */5 * * * *" to which line, can you assist. the docs page, and the video below, should help you with setting up a cron job - for some reason, the video on the docs page has been marked private. https://docs.whmcs.com/Cron_Configuration https://www.youtube.com/watch?v=_hcH4MYUifA 0 Quote Link to comment Share on other sites More sharing options...
