Chris74 Posted September 21, 2019 Share Posted September 21, 2019 I don't think this is a very good feature and I'm amazed there is no way to disable it. We provide SSL for free to all customers - we don't need any "upsell" links taking them to the shopping cart. We don't sell SSL certificates. Someone has made a really bad decision with this one. I assume lots of you have already removed this from the templates. I'm about to go fishing to find what I need to remove. If anyone already has this info I'd appreciate it. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted September 21, 2019 Share Posted September 21, 2019 Hi Chris, if using Six, your first port of call might be to use the CSS I posted in the thread below... if using a custom theme, I daresay the idea would still probably work but you might need to find the classes used in your template.. 1 Quote Link to comment Share on other sites More sharing options...
Chris74 Posted September 21, 2019 Author Share Posted September 21, 2019 Thanks Brian - that's a better way to remove it than to delete from the templates. Much appreciated. 0 Quote Link to comment Share on other sites More sharing options...
