ahrockz1 Posted August 15, 2018 Share Posted August 15, 2018 Hi! I config a default host product: *60G SSD *1G BW If my clients click on a product and they want to config its themself, what will i need to do ? They want to have more ,like: PLUS 10G SSD, 2G BW. Can i config whmcs's addons so on website, when they chose a product, they could config or just click addon and the system could automatic create a product for them??? P/s: sr i am not good at english, if you can speak vietnamese, i will be very happy 😄 0 Quote Link to comment Share on other sites More sharing options...
redit Posted August 15, 2018 Share Posted August 15, 2018 (edited) Hello @ahrockz1 You will need to look at the 'Configurable Options' which can be found under Setup -> Products/Services -> Configurable Options. This will allow you to set options that you can then allow your customers to change at time of order or for Upgrades/Downgrades. https://docs.whmcs.com/Addons_and_Configurable_Options You can then link this set of options to your product or products as needed  Edited August 15, 2018 by redit 0 Quote Link to comment Share on other sites More sharing options...
ahrockz1 Posted August 16, 2018 Author Share Posted August 16, 2018 Oh my! Thank you, but it is only show like this: 0       1 2       3 How can you configue it into a straight line and in DROPDOWN, i can not choose "non or blank"  20 hours ago, redit said: Hello @ahrockz1 You will need to look at the 'Configurable Options' which can be found under Setup -> Products/Services -> Configurable Options. This will allow you to set options that you can then allow your customers to change at time of order or for Upgrades/Downgrades. https://docs.whmcs.com/Addons_and_Configurable_Options You can then link this set of options to your product or products as needed   0 Quote Link to comment Share on other sites More sharing options...
redit Posted August 16, 2018 Share Posted August 16, 2018 Hi @ahrockz1 My guess would be that you have the new option set as a 'Radio Button' if you go back into the configurable Options section and then edit the option that you created in the top right corner you will see a dropdown of the different element types simply change this to Dropdown and you should have what you need. Â 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted August 16, 2018 Share Posted August 16, 2018 On 16/08/2018 at 08:57, ahrockz1 said: Oh my! Thank you, but it is only show like this: 0Â Â Â Â Â Â Â 1 2Â Â Â Â Â Â Â 3 How can you configure it into a straight line you would likely need to edit the configureproduct.tpl template of your orderform and change col-sm-6 to col-sm-12 {foreach $configurableoptions as $num => $configoption} {if $configoption.optiontype eq 1} <div class="col-sm-12"> <div class="form-group"> <label for="inputConfigOption{$configoption.id}">{$configoption.optionname}</label> <select name="configoption[{$configoption.id}]" id="inputConfigOption{$configoption.id}" class="form-control"> {foreach key=num2 item=options from=$configoption.options} <option value="{$options.id}"{if $configoption.selectedvalue eq $options.id} selected="selected"{/if}> {$options.name} </option> {/foreach} </select> </div> </div> {elseif $configoption.optiontype eq 2} <div class="col-sm-12"> <div class="form-group"> <label for="inputConfigOption{$configoption.id}">{$configoption.optionname}</label> {foreach key=num2 item=options from=$configoption.options} <br /> <label> <input type="radio" name="configoption[{$configoption.id}]" value="{$options.id}"{if $configoption.selectedvalue eq $options.id} checked="checked"{/if} /> {if $options.name} {$options.name} {else} {$LANG.enable} {/if} </label> {/foreach} </div> </div> {elseif $configoption.optiontype eq 3} <div class="col-sm-12"> <div class="form-group"> <label for="inputConfigOption{$configoption.id}">{$configoption.optionname}</label> <br /> <label> <input type="checkbox" name="configoption[{$configoption.id}]" id="inputConfigOption{$configoption.id}" value="1"{if $configoption.selectedqty} checked{/if} /> {if $configoption.options.0.name} {$configoption.options.0.name} {else} {$LANG.enable} {/if} </label> </div> </div> changes to... 1 Quote Link to comment Share on other sites More sharing options...
ahrockz1 Posted August 21, 2018 Author Share Posted August 21, 2018 #brian! THANKS Can you give me more details? There are a lot of files with the same name in "public_html/templates/orderforms". And is there any way to config it without changing the code? 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted August 21, 2018 Share Posted August 21, 2018 6 hours ago, ahrockz1 said: There are a lot of files with the same name in "public_html/templates/orderforms". there's only going to be one called configureproduct.tpl in your active orderform template. 😀 for the above code, i've assumed that you're using standard_cart. 7 hours ago, ahrockz1 said: And is there any way to config it without changing the code? no - because you're changing the layout, and that is controlled by the template... you couldn't really change it with a hook, unless the template was designed to be changed by it... and it isn't. 0 Quote Link to comment Share on other sites More sharing options...
