solomon121 Posted May 3, 2018 Share Posted May 3, 2018 Hello here, Please i have a friend that's using whmcs nulled v6.2, Now he has bought genuie license and he don't know what to do next. I will really appreciate your comment 0 Quote Link to comment Share on other sites More sharing options...
vinc1402 Posted May 5, 2018 Share Posted May 5, 2018 You got some balls... Your "friend" probably has some nasty code inside on his installation and I would advise you to do a clean install and start importing all data. 1 Quote Link to comment Share on other sites More sharing options...
solomon121 Posted May 5, 2018 Author Share Posted May 5, 2018 4 hours ago, vinc1402 said: You got some balls... Your "friend" probably has some nasty code inside on his installation and I would advise you to do a clean install and start importing all data. Thank, we have do fresh installation with thesame version remain to upgrade to the latest version. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS ChrisD Posted May 5, 2018 Share Posted May 5, 2018 Hi @solomon121, If you have created a fresh install and imported your data once you have a license follow the steps at https://docs.whmcs.com/Updating to upgrade to the latest release 0 Quote Link to comment Share on other sites More sharing options...
solomon121 Posted May 6, 2018 Author Share Posted May 6, 2018 5 hours ago, WHMCS ChrisD said: Hi @solomon121, If you have created a fresh install and imported your data once you have a license follow the steps at https://docs.whmcs.com/Updating to upgrade to the latest release Thanks alot, i will do that as soon as possible 0 Quote Link to comment Share on other sites More sharing options...
