SolusVM-Pro | Problem template
Ilario42
19 hours ago, Ilario42 said:
The management panel for the vps can only be seen in the WHMC SIX template and not in my ACE template.
How can I do?
I would suggest contacting the author/developer of the ACE theme that you are using and check with them to see if there is an updated version available for the WHMCS release that you are using.
Hello. unfortunately ace is its developer have disappeared in version 5.2.
It was me who brought it along for me, this template for version 7 did not work, but I was able to fix all the problems and make it work. So no one can help me as a developer, but I would ask you if you know how to solve
Best regards
