auto suspend/unsuspend is not work
TakCloud
  • WHMCS Developer
You haven't really provided any information for someone to assist you.
  • Do you receive your cron job email daily?
  • Do you see any error in your Activity Log?
  • What happens if you manually attempt to suspend an overdue service?
  • Do you definitely have some services overdue enough to warrant a suspend? You can confirm how many days after due something would attempt to be suspended in Setup -> Automation Settings
hi andrew
yes im recive cron job mail daily
not show error
manually suspend from whmcs work corectly
Suspend Days : 1
in cron job mail evry day show : Overdue Suspensions 1 Suspended
but not suspend any service and in full summary
Overdue Suspensions
0Suspended
0 faild
Edited by WHMCS ChrisD
Corrected formatting
Hello @TakCloud
There's a number of things that could be happening here causing the error.
To begin:
  1. Login to WHMCS
  2. Go to Setup > General Settings > Other
  3. Locate Display Errors and Tick this Feild
  4. Save
  5. Open your servers terminal window
  6. Run the following command
    php -q /home/username/crons/cron.php -F all -vvv
    Replacing /home/username/crons/ with the path to your cron
  7. Check the full on-screen output for errors at the suspension section
If you do not have server terminal access please follow steps 1 - 4 and ask your host to run the command providing you with the full output.
7 hours ago, WHMCS ChrisD said:
Hello @TakCloud
To begin:
  1. Login to WHMCS
  4. Save
hi
im run command and show this error :
 [ERROR] exception 'PDOException' with message 'SQLSTATE[23000]: Integrity constraint violation: 1048
         Column 'last_attempt_error' cannot be null' in
         /home//public_html/vendor/illuminate/database/Connection.php:441
         Stack trace:
         /home/public_html/vendor/illuminate/database/Connection.php(441):
         PDOStatement->execute(Array)
/public_html/vendor/illuminate/database/Connection.php(706):
         Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlCo
         nnection), 'insert into `tb...', Array)
         Next exception 'Illuminate\Database\QueryException' with message 'SQLSTATE[23000]: Integrity
         constraint violation: 1048 Column 'last_attempt_error' cannot be null (SQL: insert into
         `tblmodulequeue` (`service_type`, `service_id`, `module_name`, `module_action`, `completed`,
         `last_attempt`, `last_attempt_error`, `num_retries`, `updated_at`, `created_at`) values
         (service, 2783, esx, SuspendAccount, 0, 2017-10-03 10:47:46, , 0, 2017-10-03 10:47:46,
         2017-10-03 10:47:46))' in
  • WHMCS Developer
OK, this error means that the custom server module 'esx' is not returning any error when an error is occurring which is causing your issue here. This would need to be resolved by your module creator.
I have opened a case, CORE-11696 to better handle a null queue item in the future.
  • 2 years later...
We have the same problem,
    Do you receive your cron job email daily?   YES
    Do you see any error in your Activity Log? Nothing
    What happens if you manually attempt to suspend an overdue service?  Actually we do not use any module to suspend the service, we just need to change the status to Suspended and it is enough for us. Yes manually changing the status is work!
    Do you definitely have some services overdue enough to warrant a suspension? Yes, I have tried a few times with different situations!
Here is the output of:
WHMCS Automation Task Utility: all
 Daily Cron Automation Mode
Queuing Tasks
 Force run any tasks: ignore "in progress" and "is due"
 Task queues ready
Executing Application Queue
  0/30 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░]   0% < 1 sec/< 1 sec 18.0 MiB
 Currency Exchange Rates
  1/30 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░]   3% < 1 sec/< 1 sec 18.0 MiB
 Product Pricing Updates
  2/30 [▓░░░░░░░░░░░░░░░░░░░░░░░░░░░]   6% < 1 sec/< 1 sec 18.0 MiB
 Invoices
  3/30 [▓▓░░░░░░░░░░░░░░░░░░░░░░░░░░]  10% < 1 sec/< 1 sec 18.0 MiB
 Late Fees
  4/30 [▓▓▓░░░░░░░░░░░░░░░░░░░░░░░░░]  13% < 1 sec/< 1 sec 18.0 MiB
 Credit Card Charges
  5/30 [▓▓▓▓░░░░░░░░░░░░░░░░░░░░░░░░]  16% < 1 sec/< 1 sec 18.0 MiB
 Invoice & Overdue Reminders
  6/30 [▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░░░░]  20% < 1 sec/< 1 sec 18.0 MiB
 Domain Renewal Notices
  7/30 [▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░░░]  23% < 1 sec/< 1 sec 18.0 MiB
 Cancellation Requests
  8/30 [▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░░]  26% < 1 sec/< 1 sec 18.0 MiB
 Overdue Suspensions
  9/30 [▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░]  30% < 1 sec/< 1 sec 18.0 MiB
 Overdue Terminations
 10/30 [▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░]  33% < 1 sec/< 1 sec 18.0 MiB
 Fixed Term Terminations
 11/30 [▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░]  36% < 1 sec/< 1 sec 18.0 MiB
 Inactive Tickets
 12/30 [▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░]  40% < 1 sec/< 1 sec 18.0 MiB
 Prune Ticket Attachments
 13/30 [▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░]  43% < 1 sec/< 1 sec 18.0 MiB
 Delayed Affiliate Commissions
 14/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░]  46% < 1 sec/< 1 sec 18.0 MiB
 Affiliate Reports
 15/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░]  50% < 1 sec/< 1 sec 20.0 MiB
 Email Marketer Rules
 16/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░]  53% < 1 sec/< 1 sec 20.0 MiB
  SSL Sync
 17/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░]  56% 3 mins/5 mins 20.0 MiB
 Credit Card Expiry Notices
 18/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░]  60% 3 mins/5 mins 20.0 MiB
 Server Usage Stats
 19/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░]  63% 3 mins/4 mins 20.0 MiB
 Overage Billing Charges
 20/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░]  66% 3 mins/4 mins 20.0 MiB
 Client Status Update
 21/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░]  70% 3 mins/4 mins 20.0 MiB
 Domain Expiry
 22/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░]  73% 3 mins/4 mins 20.0 MiB
 Ticket Escalation Rules
 23/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░]  76% 3 mins/4 mins 20.0 MiB
 Data Retention Pruning
 24/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░]  80% 3 mins/3 mins 20.0 MiB
 Update Server Usage
 25/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░]  83% 3 mins/3 mins 20.0 MiB
 Update Server Meta Data
 26/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░]  86% 3 mins/3 mins 20.0 MiB
 Run Jobs Queue
 27/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░]  90% 3 mins/3 mins 20.0 MiB
 WHMCS Updates
 28/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░]  93% 3 mins/3 mins 24.0 MiB
 Domain Transfer Status Synchronisation
 29/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░]  96% 3 mins/3 mins 24.0 MiB
 Domain Status Synchronisation
 30/30 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓] 100% 3 mins/3 mins 24.0 MiB
 Sending Daily Cron Digest email
Executing System Queue
 4/4 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓] 100% < 1 sec/< 1 sec 24.0 MiB
 [OK] Completed
Here are the automation settings:
How can we check the problem deeper and fix it? do we need a module or somthing?
