messir Posted July 6, 2017 Share Posted July 6, 2017 Hi all. Guys pls help as customer support not reply couple days. My problem is: After choose hosting plan, I redirected to https://www.tongohost.com/cart.php?a=add&pid=49 where I need "Choose a Domain..." But at this step I stuck. No one of variant with domains not show field for domain and no Button for next step. Thanks 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted July 6, 2017 Share Posted July 6, 2017 My problem is: After choose hosting plan, I redirected to https://www.tongohost.com/cart.php?a=add&pid=49 where I need "Choose a Domain..." But at this step I stuck. No one of variant with domains not show field for domain and no Button for next step. it's a template / .js issue because if you use the default "Six" template, then the cart works fine. https://www.tongohost.com/cart.php?a=add&pid=49&systpl=six it appears that you're using an old v6 template with a v7.2 installation - but the v7 templates have some major differences from v6, as outlined in the page below. https://docs.whmcs.com/WHMCS_7.1_Asset_Changes what you'll need to do if it's a purchased custom template, is contact the developer for an updated version, or if it's changes you've made yourself, compare your template to Six and make the appropriate changes to the header and footer templates, and possibly others templates too. I can also see an issue with your domain registration page too - namely the pricing table not using the correct language strings... which might mean your language files are outdated too. 0 Quote Link to comment Share on other sites More sharing options...
messir Posted July 9, 2017 Author Share Posted July 9, 2017 Hi I fixed the issue. Would you give advice what to do with this template error https://www.tongohost.com/index.php?rp=/knowledgebase Thanks 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted July 9, 2017 Share Posted July 9, 2017 the error being that it's full width? it's going to be a missing/wrong .css class somewhere... if this is a v7+ release, i'd be concerned that you aren't calling all.min.css 0 Quote Link to comment Share on other sites More sharing options...
