Camotec Posted November 23, 2007 Share Posted November 23, 2007 I followed the instructions and got to Step 2 of the install and the installer is only giving me the New Install option? I am unable to choose the upgrade from 3.4.0 to 3.4.1 option. Can someone help me with this please? Cheers Ben 0 Quote Link to comment Share on other sites More sharing options...
bear Posted November 23, 2007 Share Posted November 23, 2007 Did you by any chance overwrite your configuration file in the upload? 0 Quote Link to comment Share on other sites More sharing options...
Camotec Posted November 23, 2007 Author Share Posted November 23, 2007 I only used the changed file package? how can I check this, what is the config file called? 0 Quote Link to comment Share on other sites More sharing options...
Camotec Posted November 23, 2007 Author Share Posted November 23, 2007 My Configuration.php file is intact. (I have a backup of it with all my templates etc. on my harddrive) From what I can see my page is working 100% and the Version is reporting as 3.4.1 However I didn't run the upgrade installer I just uploaded the files over the top of the ones on the server? Does this mean that I can just delete the install directory and it will work fine? 0 Quote Link to comment Share on other sites More sharing options...
bear Posted November 23, 2007 Share Posted November 23, 2007 Nice you had a backup. You should run the installer first. Often there are database changes that the installer handles, and if you don't, your files will show the right version, but things may not work properly. 0 Quote Link to comment Share on other sites More sharing options...
Camotec Posted November 23, 2007 Author Share Posted November 23, 2007 ok problem I have there is that I only get the full install option which is not right as I am only upgrading from 3.4.0 to 3.4.1 but that radio button is disabled?? go figure 0 Quote Link to comment Share on other sites More sharing options...
bear Posted November 23, 2007 Share Posted November 23, 2007 I'd suggest opening a ticket with support. Doing it wrong could kill your current data, and no one wants that. 0 Quote Link to comment Share on other sites More sharing options...
