disable webhosting recommendation when not having hosting products?
Bashar
if you're talking about the image below, then you can't do it from the settings...
... you'd need to modify the domainregister.tpl template and either remove the block below...
                <div class="{if $domainTransferEnabled}col-md-6{else}col-md-8 col-md-offset-2{/if}">
                   <div class="domain-promo-box">
                       <div class="clearfix">
                           <i class="fa fa-server fa-4x"></i>
                           <h3>{lang key='orderForm.addHosting'}</h3>
                           <p class="font-bold text-warning">{lang key='orderForm.chooseFromRange'}</p>
                       </div>
                       <p>{lang key='orderForm.packagesForBudget'}</p>
                       <a href="cart.php" class="btn btn-warning">
                           {lang key='orderForm.exploreNow'}
                       </a>
                   </div>
               </div>
... or if you want the panel to show only if you having hosting products - and for simplicity i'm counting ANY product as a hosting product (otherwise it gets complicated), you would wrap the above block in an {if} statement...
                {if $productgroups|@count gt 0}
                       </div>
                       </a>
                   </div>
               </div>
               {/if}
... and if you do have products that aren't hosting products, then you'd likely need to write an action hook to determine that for an if statement to act upon.... or just simply delete/replace the above block of code yourself. :)
