sgonzalez Posted November 24, 2016 Share Posted November 24, 2016 Hi, I am having an issue with the product addons. I have a simple hosting package, and then I have addons for that package.. for example SSL. THe problem is that when I select 4 in quantity for the primary product it automatically increases the addon also to 4.. Is there any way to order hosting package (with quantity 4) and then an addon for that package (with quantity 1 ) ? Thanks! 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted November 24, 2016 Share Posted November 24, 2016 off the top of my head, you might need to add the product/SSL addon to cart, then add 3x product/ with no addon again... when ordering multiple quantities, you're ordering the exact same product/addon/config setup multiple times. even if you could order 4xprimary product and one addon - how would WHMCS know which primary account the ssl addon is linked to? 0 Quote Link to comment Share on other sites More sharing options...
