If stage = delivered does not work in quotepdf.tpl
Tapeix
Full code:
if ($stage == "Delivered") {
$noteshtml = '<table width="100%" cellspacing="1" cellpadding="2" border="0"> blablabla </table>'; }
elseif ($stage == "Draft") {
$noteshtml = '<table width="100%" cellspacing="1" cellpadding="2" border="0"> blablabla </table>'; } else { blablabla }
Even if I try to convert it to html, the variable does not appear.
$noteshtml = '{if $stage == "Delivered"}
{elseif $stage == "Draft"}
{else} {/if}';
What did I do wrong?
Sure, full code posted below.
# Quote Items above this line (@sentq!)
$pdf->writeHTML($tblhtml, true, false, false, false, '');
$pdf->Ln(5);
# Transactions
# Removed!
# Terms
   $noteshtml = '
           <tr>
               <td>'.$_LANG["offerteb1"].' '.$validuntil.' '.$_LANG["offerteb2"].' <br><br>'.$_LANG["invoicesnotes"].' '.$notes.'</td>
           </tr>
       </table>
} elseif ($stage == "Draft") {
   $noteshtml = '
               <tr>
               </tr>
           </table>
} else {
   $noteshtml = '
               <tr>
               <td>'.$_LANG["invoicesnotes"].' '.$notes.'</td>
               </tr>
           </table>
$pdf->writeHTML($noteshtml, true, false, false, false, '');
Edited by Tapeix
are you saying the above code doesn't work? it looks fine to me... though if delivered and draft are going to be the same, i'd combine them into one if statement - but that won't be why it isn't working.
if ($stage == "Delivered" || $stage == "Draft") {
   $noteshtml = '
           <tr>
           </tr>
       </table>
} else {
   $noteshtml = '
               <tr>
               </tr>
           </table>
$pdf->writeHTML($noteshtml, true, false, false, false, ''); [/php]
It isn't working, indeed. You may try the code below yourself by using this code in quotepdf.tpl.
<?php
# Terms
   $noteshtml = '
           <tr>
           </tr>
       </table>
} else {
   $noteshtml = '
               <tr>
               </tr>
           </table>
Works well. That isn't the problem.
'.$stage.' output = 'Afgeleverd' (--> delivered
- - - Updated - - -
Hahaha :D
I just made translated the variables to Dutch and it works. Probably because I'm using the Dutch admin translation.
if ($stage == "Afgeleverd" || $stage == "Concept" || $stage == "Delivered" || $stage == "Draft") {
   $noteshtml = '
           <tr>
           </tr>
       </table>
} else {
   $noteshtml = '
               <tr>
               <td>'.$_LANG["invoicesnotes"].' '.$notes.' '.$stage.'</td>
               </tr>
           </table>
