powereclipse Posted September 22, 2016 Share Posted September 22, 2016 Hello. I have a small issue deleting products. See: https://gyazo.com/3ef050c82445fdae4007685c912ca747 I have to manually remove them from the database, which is a bit sketchy. 0 Quote Link to comment Share on other sites More sharing options...
zomex Posted September 23, 2016 Share Posted September 23, 2016 Hello, That's strange i've never seen this issue before. The first thing I recommend doing is checking under help > health and updates ensure that your server supports all of the requirements of WHMCS. -- I think I know what the issue could be, check the permissions you've set on the MySQL user of the database. If you've removed the option to drop tables (some will modify the permissions to enhance secure) then it could cause this issue. Jack 0 Quote Link to comment Share on other sites More sharing options...
powereclipse Posted September 27, 2016 Author Share Posted September 27, 2016 Hello, That's strange i've never seen this issue before. The first thing I recommend doing is checking under help > health and updates ensure that your server supports all of the requirements of WHMCS. -- I think I know what the issue could be, check the permissions you've set on the MySQL user of the database. If you've removed the option to drop tables (some will modify the permissions to enhance secure) then it could cause this issue. Jack Nah. The MySQL permissions are fine, it's not that... 0 Quote Link to comment Share on other sites More sharing options...
powereclipse Posted October 8, 2016 Author Share Posted October 8, 2016 Anyone? No one? 0 Quote Link to comment Share on other sites More sharing options...
