jpmaster Posted August 3, 2015 Share Posted August 3, 2015 Hello, We are getting this error since we upgraded to V.6.0: SQLSTATE[HY000] [1203] User already has more than 'max_user_connections' active connections Never had that problem before and we have not changed any setting on the server. All help greatly appreciated. Regards, JPMaster 0 Quote Link to comment Share on other sites More sharing options...
sentq Posted August 3, 2015 Share Posted August 3, 2015 is your website installed in VPS/Dedicated/Shared hosting? 0 Quote Link to comment Share on other sites More sharing options...
jpmaster Posted August 3, 2015 Author Share Posted August 3, 2015 It's on a dedicated server 0 Quote Link to comment Share on other sites More sharing options...
yashodhan Posted September 4, 2015 Share Posted September 4, 2015 Critical Error SQLSTATE[HY000] [1203] User xxxxxxxx_whmcxxx already has more than 'max_user_connections' active connections Same problem with me.. I am using Cloudflare as well. - - - Updated - - - In addition now following error appeared: Fatal error: Uncaught exception 'Illuminate\Database\QueryException' with message 'SQLSTATE[HY000]: General error: 2006 MySQL server has gone away (SQL: select * from `tblclients` where `id` = 126 limit 1) (SQL: select * from `tblclients` where `id` = 126 limit 1)' in /home/xxxxxxxx/public_html/cp/includes/classes/WHMCS/Terminus.php:0 Stack trace: #0 /home/xxxxxxxx/public_html/cp/includes/classes/WHMCS/Terminus.php(0): WHMCS\Terminus::whmcsExceptionHandler() #1 [internal function]: WHMCS\Terminus->whmcsExceptionHandler(Object(Illuminate\Database\QueryException)) #2 {main} thrown in /home/xxxxxxxx/public_html/cp/includes/classes/WHMCS/Terminus.php on line 0 0 Quote Link to comment Share on other sites More sharing options...
pRieStaKos Posted September 7, 2015 Share Posted September 7, 2015 Seems like you both have connection problems / limits with you MySQL server. Contact your service provider. 0 Quote Link to comment Share on other sites More sharing options...
