raeyo Posted June 22, 2015 Share Posted June 22, 2015 In Setup --> product services when I add a product (or clone) the description field and price is not saving (returns blank or default settings). It used to work but after installing few patches it doesn't work properly it seems. First thing I did was checking if folders were chmodded in right way and that was the case so it's something else which cause this problem. I urgently need to add some products now.. so anyone has a clue what to check ? Tx in advance. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted June 23, 2015 WHMCS Product Manager Share Posted June 23, 2015 Hi, This behaviour could suggest that MySQL Strict Mode is enabled on your server. Please disable it in order for WHMCS to function correctly: http://docs.whmcs.com/System_Requirements You may need to contact your server admin/hosting provider to make this change. 0 Quote Link to comment Share on other sites More sharing options...
