Problem with custom fields description.
I'm trying to add custom field description to some of my products, and the problem is, that the description looks really bad since half of it starts right after the textbox and the rest is written under it.
Is there a way to make it look better, and force the field description to start from under the text box and not near it?
Example:
s29.postimg.org/w6mt98sfb/test.png
Thanks.
the simplest way would probably be to modify the order-form template - probably configureproduct.tpl
it will likely contain the following to display the description...
{$customfield.input} {$customfield.description}
depending on your layout, you could replace the space between them with a break return or similar...
