Si Posted October 15, 2014 Share Posted October 15, 2014 Does anyone know if there is any module that has been created that will allow us to offer other products (not add-ons) as well as certain products at checkout. ? ie, if a customer purchases a hosting account, that we would offer SSL certs etc at the same time. P.S. I know about product bundles, but I think that complicates the initial buying process for the customer. 0 Quote Link to comment Share on other sites More sharing options...
vec Posted October 15, 2014 Share Posted October 15, 2014 there is a add that someone makes, the problem with these addons is that they can break when you update WHMCS, so I don't use them.... 0 Quote Link to comment Share on other sites More sharing options...
Kian Posted October 15, 2014 Share Posted October 15, 2014 Yep, I agree. Sadly too many modules are poorly made and invasive. Anyway don't worry Si It's possible if you can code it properly or if you pay a real WHMCS developer to develop it for you. I think that you'll only need an Addon Module where you create your "cross selling rules" (e.g. When there's an hosting in the cart suggest SSL Certificates and Web Design Consulting products, when there's a domain suggest Hosting and VPS products) then display them in a nice way in cart.php with using Smarty. 0 Quote Link to comment Share on other sites More sharing options...
