[Case 4849] IP Addresses not Recorded
WHMCS John
  • WHMCS Product Manager
An issue has been discovered in the 5.3.8 release that results in IP Addresses not being recorded by some server configurations. It is important to note this affects clients running PHP 5.2.0 - 5.3.6. Users running 5.3.7 and up aren't affected.
As a result a hot-fix patch is available to address it.
Applying the Hot-Fix
To apply the hot fix simply download the attached zip file, unzip it, and then upload the file contained within it to the /includes/classes/WHMCS/Utility/Environment/ folder.
No further steps are necessary.
Case4849-IPv6FixforPHP52.zip
