sahostking Posted May 3, 2014 Share Posted May 3, 2014 Hi, I have 2 currencies setup in WHMCS. The default is ZAR for South africa and the other is USD (Secondary) Now when I go to domainchecker.php?currency=2 it does nothing and leaves it on default currency ZAR. Also when I added the geoip location and test via web proxy in US it does not change aswell to US. Any ideaS? 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted May 3, 2014 Share Posted May 3, 2014 two thoughts occur to me about currency... firstly, are you sure that USD has the currency value of 2? if you have previously added a currency and then later removed it, it's currency id doesn't get used again and the counter moves on... so next currency added will be equal to 3 etc... so perhaps go to setup -> payments -> currencies ... and put the mouse over the edit button for the currency and see what the id value is in the status bar at the bottom.... that will tell you the value to use for USD also, have you added pricing for the second currency? 0 Quote Link to comment Share on other sites More sharing options...
sahostking Posted May 3, 2014 Author Share Posted May 3, 2014 Yes I thought the same thing eventually and edited the database via PHPmyadmin and checked the currency id. it was 5 added ¤cy=5 and it worked Yippee Thanks 0 Quote Link to comment Share on other sites More sharing options...
