KyPPo Posted November 9, 2013 Share Posted November 9, 2013 Hi, I have a problem with setting my default language for WHMCS 5.2.12. As it is now, default is English, and I'd like it to be Danish. I go to General Settings -> Localisation and set the Default Language to Danish (or any other for that matter), and click Save Changes. I then get the "Changes Saved Successfully!" and all should be fine, but in the dropdown box with the languages, it has English selected again. If I go to phpMyAdmin, I can see that the language setting is set to "english". If I set it to "Danish" or "danish", everything is candy, until the next time I need to change something in General Settings, at which point it reverts default language back to English (in DB: "english"). Basically, I'm not allowed to change the default language and I have to change it manually in phpMyAdmin every time a setting has been changed. Any help here would be greatly appreciated. Thanks in advance! 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted November 9, 2013 Share Posted November 9, 2013 I doubt it's a bug as I just tested this by changing my default to Danish and it stayed as Danish. it's possibly just a file that hasn't uploaded correctly when upgrading - if you used the incremental patch, you could try uploading it again, but there was talk of another update being released soon (v5.2.13 ?). 0 Quote Link to comment Share on other sites More sharing options...
KyPPo Posted November 10, 2013 Author Share Posted November 10, 2013 Well, it would be an error from installation then, as this is a fresh install directly at 5.2.12. 0 Quote Link to comment Share on other sites More sharing options...
KyPPo Posted November 10, 2013 Author Share Posted November 10, 2013 UPDATE: Turns out I was being an idiot. I had set a domain-wide cookie named "language", and this was causing the issues. Removing the set cookie, and changing the name of the cookie for the future to something else solved the problem. 0 Quote Link to comment Share on other sites More sharing options...
