vektorhost Posted September 9, 2013 Share Posted September 9, 2013 Hello I am trying to change the default order form templates to "Modern Theme" but everytime it fails. Comparison theme still there and never change. I deleted whole cache, checked my installation and everything is fine. I can provide screenshots if needed. Thank you for any help. Cheers! Koray 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted September 9, 2013 Share Posted September 9, 2013 product groups can have their own template specified that will override the default template. so you will need to look at your product groups and see if any are using the comparison template. setup -> products/services -> products/services -> select your group by pressing the edit button (next to delete button) on the right.... at least one of them must be using comparison rather than "default" (which in your case is modern). 0 Quote Link to comment Share on other sites More sharing options...
vektorhost Posted September 9, 2013 Author Share Posted September 9, 2013 Problem is solved! Thank you very much for your help Brian. 0 Quote Link to comment Share on other sites More sharing options...
gbrowne40 Posted September 11, 2013 Share Posted September 11, 2013 thanks Brian. I literally slapped my head when I saw this. Was driving myself nuts trying to understand the issue. So simple. 0 Quote Link to comment Share on other sites More sharing options...
