disaster_master Posted September 8, 2013 Share Posted September 8, 2013 I am running into multiple issues when trying to create quotes. When I modify the quantity of an item the price does not change? When I select and add a pre-defined product the quote switches from an existing client to create a new client? Also, now when I enter an item or even select a pre-defined item the sub total is either wrong or does not exist? Not sure what I did to cause this problem can anyone offer any suggestions? One thing I noticed... Before I ever added any predefined items I was able to manually enter and send a quote and it worked. This problem started AFTER I added many pre-defined items into the system.... /http://impactsocialmedia.net/markys_stuff/quote_issueJPG.JPG 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted September 8, 2013 Share Posted September 8, 2013 I was going to say that this is a bug and should be reported - as I was able reproduce it on my system. however, I had a play and I think it works fine if you remember to click "Save Changes" after you add/modify a line item or predefined product - if you add a line item and then a predefined item, I get the same problem as you see. if you modify a line, and click save changes, then it should recalculate the totals - it seems that this is the procedure outlined in the documentation. http://docs.whmcs.com/Quotes with regards to your image, and the total of 10.001, that looks a little strange and i've been unable to reproduce it locally. 0 Quote Link to comment Share on other sites More sharing options...
disaster_master Posted September 8, 2013 Author Share Posted September 8, 2013 I was going to say that this is a bug and should be reported - as I was able reproduce it on my system. however, I had a play and I think it works fine if you remember to click "Save Changes" after you add/modify a line item or predefined product - if you add a line item and then a predefined item, I get the same problem as you see. if you modify a line, and click save changes, then it should recalculate the totals - it seems that this is the procedure outlined in the documentation. http://docs.whmcs.com/Quotes with regards to your image, and the total of 10.001, that looks a little strange and i've been unable to reproduce it locally. Thank you for the reply! I stumbled upon the solution just after I made this post but was unable to edit or delete the post as it was pending admin approval. Anyway thanks again for your help! 0 Quote Link to comment Share on other sites More sharing options...
