Custom Orderform Template Customization Smarty Problem (Cart.PHP)
LeeStrong
This issue has been resolved, thanks for your help.
In main template header.tpl:
{if ($smarty.server.SCRIPT_NAME eq "/cart.php")}
The code below the if statement will show when the web address bar is cart.php.
When adding an item to the cart, or adding a product domain the web address bar shows:
cart.php?a=add&pid=4&billingcycle=annually
The if statement is then ignored and does not trigger.
Does anyone have any inclination as to why this is?
Edit: This same code works when I use a different order form. Still don't know why.
Edited by LeeStrong
I understand it should work because it seems to work correctly when using the stock orderforms, however not under the one I have created. Thanks again though, I'm about to do a more in depth search and try my best to find out why it's doing this.
I can see you've found a solution but if I understand correctly you're looking to detect if the user is on cart.php? If so you can use:
{if $filename eq "cart"}
{/if}
Or with PHP (has it's benefits in certain cases):
{php}$page = 'cart';{/php}
{/if}
{php}if ($page=='cart') { {/php}
content for cart
{php} } {/php}
Jack
