The UberHost Posted August 26, 2007 Share Posted August 26, 2007 Hey, I'm fairly new to WHMCS and need some help customizing my WHMCS. Remove Affiliate: I'd like to remove the whole affilaite option and replace it with something else, is that possible? I'm not sure what I want to replace it (on the home page) with yet, but most likely my cPanel demo, or my community forums. Also, while I was customizing I ran into this CSS Colors img256.imageshack.us/img256/8216/previewbillingtuhkf4.gif (sorry I wasn't allowed to put http ) Please look at the iamge above, you'll see how the colors are mis matched, can you please tell me where to edit these? I've been looking everywhere in the styles.css files and am unable to find it. (I need the bg 1B1B1B, not what ever that greyish color is) New Images Does anybody have an image pack for WHMCS? In the screenshotin the problem above you'll see I found some but I am on a dark bg so I need ones without the white borders. Thank You in advanced, Kevin 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted August 26, 2007 Share Posted August 26, 2007 remove affliate - yes, use the forum search option for the 83 other variations of the same question for instructions. colours - no idea what you're asking - all the style information is in the css file and the .tpls images - no 0 Quote Link to comment Share on other sites More sharing options...
Angler Posted August 26, 2007 Share Posted August 26, 2007 the background color that you are looking for is set in the homepage.tpl file for the template you are using. Just look for bgcolor="#EFF2F9" 0 Quote Link to comment Share on other sites More sharing options...
The UberHost Posted August 26, 2007 Author Share Posted August 26, 2007 remove affliate - yes, use the forum search option for the 83 other variations of the same question for instructions. Sorry, I should have searched before asking as I'm sure other people have the same question the background color that you are looking for is set in the homepage.tpl file for the template you are using. Just look for bgcolor="#EFF2F9" Thank You! I've been looking forever! 0 Quote Link to comment Share on other sites More sharing options...
