Adamski Posted February 15, 2008 Share Posted February 15, 2008 all sorted ! 0 Quote Link to comment Share on other sites More sharing options...
DaveHarris Posted July 22, 2008 Share Posted July 22, 2008 But what did you do???? 0 Quote Link to comment Share on other sites More sharing options...
KevinUK Posted September 7, 2008 Share Posted September 7, 2008 I'm sorry to bring up an old thread, but it's relevant to my question. I'm aware that the Nominet EPP module is currently in the beta version of WHMCS. I've looked at this version, but once the upgrade is done there's no ability to use Nominet's automaton system, which is fine, but I'd prefer to wait until WHMCS releases their next stable version before commiting to using EPP on a full-time basis. I'm struggling with getting GPG set up. I've added both private and secure keys to the keyring and they're listed with gpg -k. The problem I'm finding during testing is that e-mails are being generated, but the last line of the e-mail reads '*UNSIGNED*', so I assume that there's a problem with my GPG settings. Apache runs under the user nobody; I've played with different paths in the WHMCS Nominet module settings but no joy. When I run 'gpg --no-tty --passphrase-fd 0 --clearsign nominettest.txt' the shell returns 'gpg: can't open nominettest.txt: No such file or directory gpg: nominettest.txt: clearsign failed: file open error'. Can anyone offer any advice (such as modifying the gpg.conf file - it's standard so far), or if anybody can resolve the signing issue rather than offering advice then I'd be fine with paying. Thanks. Kevin 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted September 7, 2008 Share Posted September 7, 2008 you're executing the test sign command from ./modules/nominet ? path the the test .txt file would be be tmp/ consultancy for getting it working is available through WHMCS if needed - open a support ticket with them. 0 Quote Link to comment Share on other sites More sharing options...
